Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
Oprider powerchair is locked.i get the lights scrolling. i tried the two honk solution it did not work.chair fs fully charged
It happened before and i did the two honk fix.am i missing a step here?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hello Sheila,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772,as a PDF File & if you are repairing anything yourself.Remember to take a photo via your mobile on every step,i say it is best way to work.Then you can go back to check,have a nice day.I hope this was of good help,Colin
Posted on Apr 22, 2013
Why wont my jet 1 powerchair move with fully charged batterys
If the charger is unplugged and the freewheel levers are in drive position. The joystick should not have any flash lights on it, this indicates a flash code that needs to be addressed. If the lights are rippling up and down it could be locked out. some joysticks can be reset by pushing the horn button twice after turning it on within 10 sec.some are reset by pushing joystick forward until it beeps then back til it beeps this done right after startup also. otherwise there maybe something more serious going on with the chair. Strege Mobility
Oct 10, 2017 | Jet Health & Beauty
Issues with Streamer Sport Model 888WA power chair
please can you tell me how ofter the light's flash ? does there appear to be some kind of sequence ?
Dec 09, 2012 | Shoprider Streamer Sport Power Wheelchair...
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
Powerchair doesn't move 1 red light blick's on the leftside of VSI
John,
This flash code indicates that the battery needs charging or there is a bad connection to the battery. Check the connections to the battery. If the connections are good, try charging the battery.
This flash code can be seen at the following link:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
With the battery voltage too low the chair will not move. Hope this helps.
Jan 08, 2011 | Jet 7 Portable Power Chair
The chair won't power on and the batteries won't charge. I know the charger works because I have tried it on another chair. When I plug the charger into the chair the light stays green and nothing...
After you changed the batteries, did the power chair sit unused for several weeks? It sounds more like a battery or fuse issue than a charger issue. If there are blinking lights when you try to turn the power chair on (not while attached to the charger), or it comes on then goes back off by itself quickly, there may be something else going on.
1- The green light on the charger is telling you that the batteries are not accepting any more power, either they are fully charged or they have oxidized/gone solid from sitting without being put on the charger for too long.
2-The scrolling lights on the controller when the charger is plugged in just confirms that the chair is connected to the charger, so it sounds like everything is connected properly and working. The horn will work fine when it is attached to the charger as it is getting power from the wall outlet.
3- If it was a fuse issue, the lights would not come on at all when the charger is NOT attached, even after the battery has been fully charged, which is what it sounds like is going on. The fuses can blow if you operate the chair on a slick surface or one of the drive tires spin out. The batteries will be fully charged but because the circuit is not complete, the chair will not power on.
I recommend checking the fuses and changing them if necessary. You are in luck because this is a relatively easy and inexpensive fix as they are standard automotive fuses found at any auto parts store or even Walmart for around $2 each (you need 2). The fuses are located inside the gray battery covers under the seat, attached to the leads connected to the battery cables. The straps holding the covers on the batteries are tight, you may want to use a flat head screwdriver to help release the clips. While you are down there, inspect the tread on the tires, if it is worn or slick it may need to be replaced for safety.
I hope this information is helpful to you- good luck!
Dec 17, 2010 | NRS Hoveround MPV 5 - Used Power...
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
WHAT MAKES THE CHAIR NOT MOVE WHEN CHARGING?
You cannot make a powerchair operate while it is charging. For safety purposes the power cuts out when charging batts. The only power is going to the batteries.
Feb 26, 2009 | Jet 3 Ultra Power Chair
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
