Question about HP (344872-001) Laptop Cooler, Cooling Fan
HP 2000-412NR cooling fan
Receiving cooling fan error message and laptop shuts off
    Sergeant:
  • 303 Answers
Mine did that because the CMOS battery was bad either that or the fan is worn out and will need a new one
Posted on Jan 30, 2014
We just had the regrigerator installed today. It was cooling and then we put the food back in and shut the doors and the readout now on the display where the temperature is says ER and CF. The water does...
If the unit was just installed you would call for service. Error Code Er CF -The unit will receive signals from the BLDC fan motor in the freezer compartment during normal operation. If more than 65 seconds pass without a signal from the fan motor, an "Er CF" error message will be displayed. The Cooling Motor Error is usually an indication of a faulty fan motor or loose leads. Customer service should be contacted immediately. IF you have any further questions message me back Thanks Rick
Sep 08, 2011 | LG LFX28978
Hi, My notebook is Hp presario cq series While i start the machine the cooling fan is not revolving and i hear some error message regarding the seriousness of the fan problem, A couple of days back...
Compaq notbook Presario 1626 is now officially retired at HP
https://support.hp.com/us-en/retired-products
beep codes, count them report them>>?
how to fix something but but dont touch it>? the is impossible
think that trough?>
most pcs pack in lent every year, its needs service
if not up do doing that your self, try a shop?
the fan must blow and keep the CPU cool or it overheats and fails
the CPU will shut its self down, if it overheats. ending all things..
until its cleaned fully.
google or you tube this. act.
hp forum is here.,
https://h30434.www3.hp.com/
Jul 17, 2017 | Compaq Presario 1626 Cooling Fan Case...
I would like know the method for edit error of hp laserjet P3005n error 57.03. Please suggestion or method for edit to me Thank you .
Hello Niramon,
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified during device power up. Fan operation occurs only during power up or during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan. Verify that the fan is connected to connector J512 on the ECU PCA. You might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
Jun 13, 2011 | HP LaserJet P3005n Printer
My cooling fan has shut off and the computer is telling me that there is an error but I don't know how to fix it
If the internal fan is not working you will need to disassemble and replace it. Could be that some object has lodged in the fan causing it to not spin. If you do not know how to disassemble you may want to have a repair shop look at it.
Jim
May 01, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
I have HP Probook 4510S since a year.In summer season it gets over heat and suddenly shut down.Even while its on plane surface... it works fine while its in my LAP
The feet may have popped off the bottom, where the vents are located. Either replace the small feet (they just stick on) or set the laptop on a cooling stand so that the bottom is exposed to the air. You may also want to clean the vents.
Please remember to vote for me if you like my solution.
Apr 07, 2011 | HP ProBook 4510s Notebook
How can I clean my heat sink cooling fan?
Hello Friend,
  • Do you find that the keyboard and the bottom of the laptop are very hot? Or the cooling fan of the laptop is noisy? Or the laptop suddenly shuts off but no warning and error message? Why?
  • That may be the problem of the cooling fan and heat sink. They may be dirty, and failure to maintain cleanliness on the inside of the box can and will result in overheating, and sluggish performance due to high temperatures.
To clean : 1.Remove the keyboard, access the cooling modules (fans and heat sink), you do not need to disconnect the keyboard, just place it face down on the palm rest.
  1. 2. Spray compressed air inside both cooling fans and sink heat. You can use canned air sold in any local electronics store.
  2. 3. Connect the keyboard.
If this Helped you,DO RATE ME.. Thanks for Contacting FixYa
Apr 20, 2010 | Acer TravelMate 2480 PC Notebook
HP Pavilion dv4000 Laptop There is a error message coming on my screen it says "104-Unsupported wireless network device detected . System Halted . Remove device ad restart." .I was cleaning my Laptop as...
Try the connectors near the WiFi receiver. The message is relative with thw wireless section. Try remove it from the device manager and reinstall it.
Stelios.
Feb 23, 2010 | HP Pavilion dv5000t Notebook
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
Computers & Internet Logo
122 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
