Question about HP LaserJet P2015dn Printer
I need to guid me for the both side printing of 2015 printer
Nothing others
Look under "printing Preferences" or "properties" (varies by printer model) when you select "print", and it should be under a button like "finishing", it's right there somewhere, just click a few 'buttons.
Also make sure you have the proper "DN" driver installed (the "D" stands for "duplex" (double-sided printing). If you have just installed the regular driver , the duplex feature may not be available
Posted on Mar 17, 2009
Stuck on welcome page need help
Search Results
    Hp envy stuck on welcome screen - HP Support Forum ... > ... > Video/Touch
    Oct 2, 2014 - 5 posts
    I have rebooted twicw but it just stays stuck at the welcome screen. ... next page in the first column , under "I need help immediately" you need to ...
    Windows 10 Stuck on Welcome Screen - HP Support Forum ... > ... > Boot
    Aug 15, 2015 - 3 posts
    Inkjet Printing; LaserJet Printing; Printer Software and Drivers; DesignJet .... Windows 10 Stuck on Welcome Screen ... It is a great place to find the help youneed, both from other users, HP experts and other support personnel.
    Stuck on welcome screen - HP Support Forum - 4902534 > Laptop & Notebook > Lockups/Freezes
    Feb 23, 2015 - 2 posts
    My new desktop gets stuck On the welcome page. ... Also you need to uninstall and reinstall the problem software on your ... Hope this helps.
    Windows 7 Stuck Loading at Welcome Screen [Solved] - Windows 7 ... > Forum > Windows 7
    Tom's Hardware Guide
Dec 29, 2015 | Office Equipment & Supplies
How to fix double vision print?
The duplicate print is a problem you can fix easy, only need...
1. calcium grease
2. and put in the iron making
with the next steps...
Solving problem of duplicate letters in Canon printers
Nov 19, 2015 | Canon PIXMA MG3550 Inkjet Multifunction...
Loaded ribbon correctly according to Zebra S4M Quick Reference guide....but won't print anything on labels.
The ribbon has wax just on one side. So, if nothing prints on the label, first thing I'd check if the ribbon loaded with waxed side facing label.
Jan 11, 2011 | Zebra S4M Thermal Label Printer
Alarm light flashes, and I can't print anything. a box comes up on my computer screen that says Service Error cancel the printing and push OK on the printer. Nothing works!
First allow the printhead to cool down. Disconnect the USB cable, plug it back in. Turn the printer on and off and check for any obstructions or paper jams. (Look specifically along the print head path.)
This error usually indicates a problem with the paper path (or pick up) for Canon Printers. There is a guide that needs to be exactly positioned relative to the chassis and it can come loose. Servicing this is complicated - you need to remove the sides and the bottom of the printer then check the guide position. Finally you disconnect the Logic board and loosen mounting screws. Reset the guide and reassemble the printer. (You will need a detailed set of pictures for the positions and I don't have one for this printer.)
Canon recommends you send the unit for service if there first set of solutions do not work. (That's the check for obstructions section.)
I wish that I could be of more help.
Jun 27, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I have a mfc 440cn and i can not print ANYTHING from my computer. Everything seems to be setup and hooked up right but nothing happens. I have windows xp. I can fax, scan, copy but it just will not print...
Have you rebooted your computer and restarted the printer? If so, try this solution, to begin with. See the home support page here, the printing troubleshooting site for your model here, or the install and setup guide here.
But I'm thinking this sounds like you need to clear the print queue in windows. Instructions for that here, and other troubleshooting guides for printing problems in xp here. If the printer appears to be functioning ok in the device manager, you can also try using the xp printer troubleshooter available from the Printers and Faxes section of the control panel to guide you through possible solutions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | Office Equipment & Supplies
User cannot print on both sides
The easiest solution to this is to ask the system admins at customer's place to install another driver for this printer - but with other settings - allowing duplex printing. The user can then chose the drivers he needs without having to open them for reconfiguration.
Mar 10, 2009 | HP LaserJet CP3505n Printer
Printer prints blank on paper
Open the door half way through a page print and pull out toner cartridge. The page should be in the toner cartridige. If you can see the printed image then the fuser is the problem if you see nothing then the toner is bad or has a protective sleeve inside that needs to be pulled out from one of the ends.
Jan 08, 2009 | Canon LBP 800 Laser Printer
Have the Basic Guide for new MF4150 Canon copier...need Advanced
My solution is to find better support than you have given...which is nothing! Please do not write again
Thank you, Denise Olsen
Nov 18, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Can't print landscape?
Make sure the correct printer driver is installed.Check your user guide.Read the information below.
Printer Settings
You can use the printer properties window, which allows you to
access all of the printer options you need when using your
printer. When the printer properties are displayed, you can
review and change the settings needed for your print job.
Your printer properties window may differ, depending on your
operating system. This Software User’s Guide shows the
Properties window for Windows 98.
Your printer driver Properties window that appears in this User’s
Guide may differ depending on the printer in use.
If you access printer properties through the Printers folder, you
can view additional Windows-based tabs (refer to your
Windows User’s Guide) and the Printer tab (see “Printer Tab” on
page 10).
• Most Windows applications will override settings you specify
in the printer driver. Change all print settings available in the
software application first, and change any remaining settings
using the printer driver.
• The settings you change remain in effect only while you are
using the current program. To make your changes
permanent, make them in the Printers folder.
• The following procedure is for Windows XP. For other
Windows OS, refer to the corresponding Windows User's
Guide or online help.
1. Click the Windows Start button.
2. Select Printers and Faxes.
3. Select your printer driver icon.
4. Right-click on the printer driver icon and select
Printing Preferences.
5. Change the settings on each tab, click OK.
Layout Tab
The Layout tab provides options to adjust how the document
appears on the printed page. The Layout Options includes
Multiple Pages per Side and Poster. See “Printing a
Document” on page 6 for more information on accessing printer
Orientation allows you to select the direction in which
information is printed on a page.
• Portrait prints across the width of the page, letter style.
• Landscape prints across the length of the page, spreadsheet
• Rotate allows you to rotate the page the selected degrees.
Layout Options
Layout Options allows you to select advanced printing options.
You can choose Multiple Pages per Side and Poster.
• For details, see “Printing Multiple Pages on One Sheet of Paper
(N-Up Printing)” on page 12.
• For details, see “Printing Posters” on page 13
Jan 16, 2008 | Samsung ML 2010 Laser Printer
HP LaserJet P2015dn Printer Logo
127 people viewed this question
Ben Johnson
