Question about Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD)
Seagate momentus 5400.6 drivers download
I have this hard drive and want to reinstall windows as the hard drive is broken and know I have found out that there is no drivers for it how do I download and install the drivers on the drive?
    Top Expert:
  • Seagate Master
  • 52,053 Answers
If it is broken thenit will not take drivers anyway .
Posted on Oct 16, 2015
shadow5599
  • 51 Answers
SOURCE: Seagate momentus 3 60gb problem
What software did you use for the cloning?
Ghost is the preferred method.
Be sure to choose a disk to disk clone, not a partition clone.
It sounds like you may have created a 20G partition and left 40G unallocated.
Partition Magic may also take care of the problem, if you have access to a copy.
Posted on Oct 16, 2007
  • 44 Answers
SOURCE: Windows
I've just installed the same type of hard drive in my PC running win XP and have no problems.. do u know that you need to format the disk before it will show up with the other accessible drives?
what to do is - click start, right click on my computer and go to manage.. then double click on storage, disk management local.. and it should show up here, once you format it your all set..
No need for drivers, windows has them already, it's all generic one's the windows is familiar with..
Hope this helps!
Posted on Dec 16, 2007
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
SOURCE: how do i format the seagate 5400 160 gig hard drive?
Configuring the BIOS
After completing the drive installation, restart your computer. Your computer
may automatically detect your new drive. If your computer does not
automatically detect your new drive, follow the steps below.
1. Restart your computer. While the computer restarts, run the system
setup program (sometimes called BIOS or CMOS setup). This is usually
done by pressing a special key, such as DELETE, ESC, or F1 during
the startup process.
2. Within the system setup program, instruct the system to auto detect
your new drive.
3. Save the settings and exit the setup program.
When your computer restarts, it should recognize your new drive.
There ya go ya tubby *****.Give me a shout this weekend, Mike
Posted on Apr 16, 2009
  • 3940 Answers
SOURCE: I HAVE A SEAGATE MOMENTUS
If your HDD is not being detected by your portable system trouble shooting is fairly direct:
  1. Remove and re-seat the hard drive to ensure the connection to the system is effective, sometimes there is enough play that over time the connection loses contact due to thermal expansion/contraction and re-seating the drive resolves.
  2. Reset the BIOS default settings. This can be done from within the BIOS (F2 at boot for most systems, F1, F10 and DEL are the other most common entry prompts, watch you screen at boot for BIOS/SETUP access prompts if unsure) Check the Hard Drive Controller Settings/SATA controller settings and write them down, and once you reset the BIOS defaults, check them again. If they have changed, set the controller setting back to the pre-reset setting to avoid 0x0000007B controller errors on reboot. Most Phoenix brand bios can be reset by pressing F9, Enter. Others will have a maintenance section where default settings can be restored. After resetting, save changes and exit this will force re-numeration of all devices by the system, including the hard disk drive. If using a desktop chassis and you have multiple controllers, swap cables with a know working controller (Usually the Optical drive) and see if the drive is detected on that cable and controller and the optical drive on the HDD controller.
  3. If the Hard Drive is still not detected, you can remove the hard drive and install it in a USB external drive case and see if the drive is detected on another system. If it is not, then the drive has failed, and needs replacement. If the drive works in the USB adapter then the controller is suspect on the system the drive was removed from, and a motherboard replacement is likely the end result.
Posted on Jul 17, 2011
Replacing acer aspire hard drive
use the ultimate boot cd to fix hdc
or boot os disk then hit f6 for third party drivers then load mass storage driver for your laptop so replaces the one on the new hard drive. video on ultimate boot cd in link advance to 52:41
PC Diagnosis and Repair
Jul 13, 2017 | Acer Computers & Internet
I have this seagate momentus hard drive, i had windows home buitin and then i upgraded to 8, after that i formatted my reserved and recovery parttion as i wanted a clean intallation and now i cant see my...
First off....8 is not an upgrade, Win 10 is an upgrade.
Forget looking for any data from your old hard drive as it has been written over and you cannot retrieve it any longer. Just obtain a copy of Windows Ten or pay for a new updated disc. Let Windows format the hard drive and install itself for you.
Feb 08, 2018 | Seagate Momentus 5400.6 (ST9250315AS) 250...
Momentus 5400 fde.3 formatting error
Which operating system ?
If windows 7 click start richt click on computer select properties then device manager scroll to your disk (hard drive) expand right click select update drive software
Every Seagate drive requires a few firmware updates during its lifetime.
Seagate firmware must be up-to-date to ensure that the product will run reliably.
Changing the firmware on a Seagate product to a more updated version will improve the product's performance.
Check the Seagate website often for any update available for your drive.
The firmware can be changed with just a few clicks of your mouse on the Seagate Web page.
Click the "Start" button on the bottom-left corner of the screen.
In the window that pops up, click " My computer " or just "Computer."
Another window will show up with an icon for your hard drive.
Right-click the hard drive icon and press the "Properties" option.
This will tell you what model your hard drive is.
For example, your hard drive might be ST31500341AS.
Open your Web browser. Type in www.seagate.com and press "Enter" on the keyboard.
Wait for the webpage to load.
Enter the word "Firmware" and your model number in the search box on the upper right hand corner of the webpage and press "Enter" on the keyboard.
Using the example from Step 1, type in "Firmware ST31500341AS".
Click on the first link that is returned in the search results.
Locate the firmware update. Double-click the update.
Press the "Download Firmware Update Utility" link to start downloading.
Click yes on any pop-up boxes that you may see.
Open the new firmware file by double clicking the file that you downloaded in Complete the installation by accepting all of the default questions that are asked during the installation process.
Hope this helps
Nov 03, 2012 | Seagate Momentus 5400 FDE.3 320GB Hard...
Seagate Momentus 500GB hard drive on a Dell Latitude laptop running Windows XP with an Excel spreadsheet open. I went away for about 20 minutes, came back and unlocked the user and then blue screen with...
This is a typical hard drive failure scenario, please check if your computer has valid contract if so get your hard drive replaced.
If you have valuable data in your hard drive and willing to spend you can go for hard driver data recovery which is an expensive process.
Jan 04, 2011 | Seagate Momentus 5400.3 Hard Drive
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
I need the driver for your momentus 5400.2 hard drive
U have install all drivers properly in ur hard drive it can be work properly
Jul 11, 2009 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
Oct 16, 2007 | Seagate Momentus 5400.3 Hard Drive
Seagate Momentus 5400.6 (ST9250315AS) 250 GB SATA Solid State Drive (SSD) Logo
3,584 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
