Question about Pool & Spa
K37GWBLE-609 spa pump
THINK THE SANYOU SLA-S-124 DM IS BAD WHERE CAN I GET ONE
Intex pure spa motor isn't circulating water, but the bubbles work. What's wrong? I think I have tried everything. Help!
Probably bad control box for the jet motor/s if the motors are running could be bad pump or a pipe valve issue. Or is there a separate blower?motor that feeds the bubbles (air)
May 25, 2015 | Intex Pool & Spa
Air pump not working and red light stays on reset. Is the pump bad or electrical problem?
It is a toy spa after all, not really meant to last long.
According to Intex, your fault code is due to low or no water flow. Most common problem that we see is bad filter. You either need to clean, soak, or just replace them! Because they are so small, I wouldn't even bother with cleaning them, just have a few handy, and just install new ones.
Apr 12, 2015 | Pool & Spa
Indoor swimming pool has bad smell only when running spa pump or ozone pump with lots of foaming
Hi.. I tell my customer to boil a glass jar and lid, like your canning. and use this jar to take the sample of water out of your pool - spa to have tested, take it to several places to have it tested.
and ozone pumps are not good to run inside in a open environment, I think the produce positive ions. but kill bacteria and odors, so if this is a SPA run the pump and ozone generator for a few days with the correct amount of anti foam and cover on it should clear right up. to avoid this problem pool and spas must have the pump on a timer or set to circulate !
if your not going to use your portable spa for say a season you must drain it !!! and drain the pumps. this will ensure that you get many many happy years of service out of your pumps and spa.
Hi; I'm Jay the pool pump motor repair guy in sunny longwood Florida. were the pool is always open, so jump in and get wet the waters just fine.
REMEMBER GREEN POOLS ARE DANGEROUS. children can fall in and not be seen costing valuable rescue time !!!
a clean pool is a safer pool "pool pump repair puppy"
Dec 29, 2012 | Pool & Spa
Have an emerson spa motor in my sundance hot tub it runs for 2 min. and cuts off I think it is overheating. what do you think it is,
do not run it , get it repaired , the start switch is stuck or it has a bad capacitor.. keep running it yo stand the chance of burning up the motor . TAKE NOTES ON HOW THE WIRES GO !!!! jay.. pump guy in longwood fl
May 15, 2011 | Emerson Pool & Spa
Coleman 500 series SPA 50A circuit breaker trips
bad connection follow wires from breaker to to moter theres abreak causing arc find it
May 08, 2010 | Pool & Spa
Pool & Spa Logo
81 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
