Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Cant share internet using a router
Cannot share internet using d-link router, my internet connections is globe broadband. the status of my LAN connections is connected
  • turbolinux May 11, 2010
    Can you tel me how did you configure your router? Did you setup as a DHCP server or do you must enter your network connection settings in your laptop manually?
  • 45 Answers
Hi There, what model of dlink router do you have?
Also, Or just check the ports you have in your router, the internet should be connected to the WAN port and the switch and/or computers to the LAN port(s).
If the router is new by default you should be able to access internet by plug everything the way I told you.
Also, by default the router ip address should be, type that into your web browser address bar, then you will have access to the router admin web page were you can see the status page, there will tell you if you have or not access to Internet really. Maybe the problem is that the router have no access internet access at all.
Posted on Mar 19, 2009
I have a CDR King Router L8186. I want to put a password
i had the opportunity to use both Smart Bro and Globe broadband internet with my CD-R King LP-8186 router. I had decided to document the configuration steps for both. For the most part, the steps indicated herein apply to both Smart Bro and Globe except otherwise mentioned in some areas. I had included the screenshots that would really matter and excluded the configuration that I left to their default values or settings. 1operation-mode.jpg?w=477&h=370
Here's the LAN Interface Setup that applies to Globe. Please note that DHCP has been disabled because the modem that came with my Globe broadband subscription has DHCP enabled thus the need to disable the DHCP server of the LP-8186 router. Also, the default gateway of is the IP address of my Globe broadband modem which is a Prolink Hurricane 5200 modem.
The last part to be configured is the WAN setup. This screenshot applies to both Smart and Globe.
Lastly, if you are using Smart Bro, the RJ45 connector from the Smart Bro canopy antenna must be connected to the WAN port of the CD-R King LP-8186 rounter.
If you are using Globe, the Prolink Hurricane 5200 modem must be connected to one of your LAN ports (not to the WAN port) of the CD-R King LP-8186 router. With Globe, the CD-R King LP-8186 acts only as an access point and all computers connecting through it are actually using bridge networking.
Sep 05, 2011 | Computers & Internet
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address ( by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type ( is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Connecting PSP to wifi
    Change the primary DNS of your PSP to and secondary dns to
    Apr 25, 2009 | Linksys WRH54G Wireless Router
    Cant connect to xbox live with vzaccess!! please help...
    You have two options. Number 1, plug the 360 into a LAN port on your PC and set up the LAN connection to share the internet with the VZaccess connection. This will work as long as you are connected through vzacess manager.
    Option number two, get an EV-DO router, wireless or wired, and use it to connect the xbox.
    If using option 1, you may have to struggle at first with the IP settings. Make sure the LAN connection AND the 360 are set up to configure IP and DNS automatically. And make sure that you set the sharing options to include http and such. more help can be found by searching in Windows Help for ICS (internet connection sharing)
    Jan 11, 2009 | Microsoft Xbox 360 Console
    D-link cant accesed internet 4pc
    Most of DSL modems are connected to PC with USB cable...
    n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
    Following are the steps to enable Internetsharing for other pcs.
    How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
    On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
    1. Log on to the host computer as Administrator or as Owner.
    2. Click Start, and then click Control Panel.
    3. Click Network and Internet Connections.
    4. Click Network Connections.
    5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
    6. Click Properties.
    7. Click the Advanced tab.
    8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
    9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
    10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
      address Your computer may lose connectivity with other computers on
      your network. If these other computers have static IP addresses, it is a good idea to set them
      to obtain their IP addresses automatically. Are you sure you want to enable Internet
      Connection Sharing?
    11. Click Yes.
    The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of and a subnet mask of
    let me know if it helps.
    best regards,
    Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
    PPPoE over Edimax BR-6104K without a modem
    I am not sure if I understand you well.
    You say:
    My Internet is a PPPoE broadband connection but I don't have a modem installed.
    What do you mean ?
    You have a Broadband/ADSL modem, but you didn't install any software for it ?
    (It is probably not necessary.)
    So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
    Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
    If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
    First RESET your Edimax router and disconnect all LAN cables if connected.
    Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
    Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
    Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
    Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
    After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
    Right-click on the network icon and click STATUS, a window will open
    and then click on SUPPORT tab.
    You should see:
    IP Addres:
    Subnet Mask:
    Default Gateway:
    Open your browser and type
    Now login as:
    admin (default)
    and password is: 1234 (default)
    Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
    Click on 'More configuration'
    Type your User Name and Password you have from your ISP.
    Now Click on APLY, and again APLY !
    The Router will restart in 30 Sec, and your NIC will reconnect.
    Now connect your Modem to a WAN port of your Router with LAN cable. (***)
    if you've typed your User Name and Password correctly in PPPoE fields,
    if everything is OK with the service from your provider,
    you should now be on Internet.
    If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
    Now, get to the PC with two NICs.
    Go to Control Pannel, and go to Network Connections.
    Right-click on one of your NICs and click 'Disable'.
    Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
    Connect the (enabled) NIC with LAN cable to another port of your router.
    The second PC should be on Internet, too.
    If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
    That's it!
    Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
      Actually in short  "you NEED A MODEM;"
    In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
    this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
    Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
    What is a gateway router?
    A gateway router lets multiple users on an Ethernet LAN share a single broadband Internet connection instead of having to use individual links. It also offers security features to protect the network from various threats.
    Feb 16, 2006 | 3Com (3CR856-95-UK) Firewall
    Open Questions:
    See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
    D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
    338 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
