Question about LG RHT599H 500GB HDD DVD Recorder with Freeview
Disk won't eject
I inserted a disk this afternoon into my machine. Unfortunately, not only did the machine not seem to recognise the disk, but it now won't eject. It's stuck on 'read' and if I switch off and back on, it makes no difference. I also can't change back to HDD mode without switching on and back on. I can't seem to find a manual release for the drive and and I just want to get the disk out. Any thoughts will be gratefully received. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
Posted on May 30, 2017
Vw beetle cd player wont read
The player may need replacement, especially if you have used it for more than a few years
May 08, 2013 | Car Audio & Video
My game won't work because it need's a update
This can be a fairly easy fix if done correctly. I am a repair tech in Ga. and recently ran into this little trickster of a problem. Try this,,,
Power the console off. Press eject and insert a DIFFERENT game (I always use the Halo 4 install disc)
Your system is looking for a required update but it seems the disc you are using may be corrupt or damaged.
After trying a different game disc it should work out for ya. If not you can try this method.
Eject any discs. Power system off.
Find a 1-2GB USP flash drive and follow the instructions on this microsoft website...
http://support.xbox.com/en-US/xbox-360/system-updates/system-updates-info
If you still have problems you can call 1-800-4MYXBOX
Mar 16, 2013 | Microsoft Xbox Video Game Consoles & Games
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Jan 25, 2013 | Coby TF-DVD1540 15 in. TV/DVD Combo
Can't figure out how to insert SD card in Lenovo thinkpad T420
Typically there is an spring-load eject on laptop card readers. If you inserted it correctly, then you can gently push the card in about 1/4 inch, it will click, and it will eject when you release it.
Nov 28, 2011 | Lenovo ThinkPad T420 Notebook
PS3 won't accept certain disks. A few disks i have won't play in my ps3. it happens to both blu-ray movies and games, and it seems to only happen with blu ray disks. i'll put the disk in, and...
Hello
The noise is actually a product of dust from a blue ray disc.Over time these discs heat up and leave a residue on the blue ray lens.
Try using a lens cleaner to remove dirt and clean lens.
Also i read an article that using a wireless controler can also cause freezing of the blue ray.
Oct 01, 2011 | Sony Playstation 3 (PS3) Console
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
I put pictures in the cd but now it won't eject. It dot stuck inside. I could not eject even if I clicl computer then click eject, it won't eject
Power off the notebook, remove power cable and battery. Then try inserting a paper clip into the small hold in the CD drive to force eject the tray. Make sure you have powered off device and removed battery before you attempt.
Jul 10, 2011 | Fujitsu LifeBookS6120 Notebook
Braun tassimo does not recognise cleaning disc, but does work wit coffee pod!
The problem is that the barcode on the cleaning disk is recessed unlike those on the pods. It seems that the reader has difficulty reading the barcode that is slightly further away than normal.
I've had this problem this afternoon and solved it by carefully peeling off the barcode from the cleaning disk and "fattening it up" with foam tape then re-applying to the plastic cleaning disk. Works perfectly now, just as well as I was close to throwing the whole machine at the wall.
Hope this helps someone
Dec 30, 2010 | Braun Tassimo Coffee Maker
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
LG RHT599H 500GB HDD DVD Recorder with Freeview Logo
87 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
