Question about Chrysler Vehicle Parts & Accessories
Chrysler 30 hp (1980) runs fine in the beginning but once run for a few min it loses power then wont idle
Cleaned carb. Changed fuel line and primer bulb
    Problem Solver:
  • 11 Answers
Have you tried draining the gas out and adding new gas? You may have bad gas or water in the gas.
Posted on Dec 08, 2013
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
Get my 1980 Suzuki GS8750L to run when I turn throttle..it starts n runs fine otherwise..idles wonderful
Is the fuel flowing freely? Definetly a fuel/air starvation issue. Something really simple such as blocked tank filter ,even a blocked exhaust,next doors cat isn't stuck up the pie nis it??
Oct 05, 2014 | Motorcycles
30 hp evinrude outboard, running full throttle, then surges as if running out of gas. Will conk out if not taken back to idle. Whats causing this?
Sounds like air is getting into the fuel line. If you have a squeeze bulb primer check to make sure that it stays firm after you run it a bit. I had an air leak on a clamp attaching the primer bulb to the fuel line and the same thing happened to me. When the engine starts to cut out squeeze the primer bulb and see if it starts running better, if it does then you probably do have an air leak in the line and it is losing it's prime. Hope this helps!
Feb 19, 2013 | Boating
18.5 hp 42 inch cut, craftsman riding mower loses power after 10 min.
Us start here, remove fuel line from carb. Hope fuel runs out.
Check the direction of fuel filter. There arrows on it. Arrow toward
carb.
Aug 09, 2012 | Craftsman Garden
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
Changed primer bulb and now wont run with throttle idles fine
If it has a remote primer you need to make sure you have connected it up the correct orientation, the primers pull fuel from the carm, and dump back to tank, they do not push fuel into the carb, the longer of the two pipes on the back of the primer is the pressure side so goes back to the tank, not the carb.
Aug 26, 2011 | Garden
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
I have a 1990 isuzunpr 4bd1t diesel.Truck won't stay running.It is a fuel issue.Drained water seperator,changed fuel filter,cleaned inline screen before the primer pump.Had primer pump rebuilt.Replaced...
G'day
I dont know if this will help but i had a similar problem with an isuzu sbr and after doing all that you have done i took the fuel tank off and drained it. Every thing looked fine so i washed it out with a little bit of petrol and a small piece of clear plastic came out. What it was doing was floating up when the truck was not running but after i started the truck it would slowly get sucked down to the outlet and block the fuel line.
It was very frustrating and it took me quite a while to find the problem.
hope this helps.
Dec 06, 2010 | 1992 Isuzu Trooper
Chrysler 70 HP outboard motor dies when pushing throttle
I have found that 99 percent of the time when this happens it is carb related. It is very possible that you picked a a small piece of grit or trash in the high speed jet of one, or both, of your carbs. I would be willing to bet that pulling the carbs and cleaning them will resolve your problem. I am almost positive that will fix your problem, mainly because it sounds like you've already tried everything else. I had this same problem last season, and what had happened was I left the vent open on my fuel tank, we got a shower, and I pulled just a small bit of water into the carb and that was it, she would not do anything over idle until I pulled the carbs and cleaned them. i even put the water muffs on it and let it run in the yard for about an hour thinking that it would burn the water out, but i was wrong. Anyway, clean the carbs and i think you'll be in good shape, Good Luck.
Jul 31, 2009 | Boating
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
