Question about Emerson Televison & Video
K37GWBLE-609 INFO ON THE PUMP
Tip
How to connect my iPod to a Pioneer PDR-609
<p>The Pioneer PDR-609 is a personal CD recorder used in conjunction with the rest of your home audio system. The equipment has a few audio inputs, however, so you can connect external devices to play through the Pioneer PDR-609, including an Apple iPod. You need a special adapter cable, but once connected, the sound from your iPod through the speaker Pioneer system. <br /> <p><br /> <p>1. Connect the end of the cable 3.5 mm headphone of your Apple iPod. <br /> <p><br /> <p>2. Insert the red and white RCA cable ends into the "Line In" port on the back of the Pioneer PDR-609. <br /> <p><br /> <p>3. Power on the iPod and the Pioneer equipment. Select "Line In" as the display option in the Pioneer, then the song you want to listen to your iPod and press select "Play". The music now plays through the speaker system of the Pioneer system. <br />
on Aug 09, 2011 | Apple iPod touch
Low oil pressure toyota camry
Is this high mileage vehicle? If so, I doubt changing oil pump will help, you may need engine overhaul?
Sometimes, you use an analog pressure gage in place of the oil pressure sending unit, to read actual oil pressure. My info says at idle, oil pressure 4.3 psi or more. At 3000 rpms, it says 43--78 psi.
Oct 14, 2017 | Cars & Trucks
What is the contact for sevice and maintenance in new jersey?
Appliance parts America
554 RT. 18 North
East Brunswick, New Jersey 08816
P (732) 238-6738
F (732) 257-7750
Info@NJApplianceParts.com
Tri Country Appliance Repair
414 Columbia Blvd
National Park, NJ 08063 (856) 845-7158
(609) 345-2018 Atlantic City Area
Dec 21, 2010 | Malber WD1000 Front Load Washer/Dryer
I need the manual for sunpentown sf-609 too, please
here is the link for the manufacture support page. If has a toll free number for help. If they cant help you, let me know and I will try to get a copy of the manual from them using my company.
http://www.sunpentown.com/info.html
Thanks
Richard
Jun 23, 2009 | Sunpentown SF-609 Air Cooler with Ionizer...
Sunpentown SF-609 Evaporative Air Cooler - no cool air
Sometimes there is a separate switch to turn on the water pump. No water=no cooling. Check to make sure the cooling pads are wet! If they are completely wet and the fan is blowing it should cool.
Jul 06, 2008 | Sunpentown SF-609 Air Cooler Fan
Televison & Video Logo
138 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
