Question about Linksys by Cisco Linksys EA6500 Smart Wi-Fi Dual-Band AC Router with Gigabit and 2x USB
Problem cannot to i-cable router - Linksys by Cisco Linksys EA6500 Smart Wi-Fi Dual-Band AC Router with Gigabit and 2x USB
  • Linksys by C... Master
  • 7,733 Answers
Power off Cable Modem, PC, router, and then disconnected them. Directly connected Cable Modem with PC (Don't connect the router) and power on Cable Modem. When Cable Modem is ready with LED lamps under normal status, also power on PC and try to access Internet service. If Internet service is resumed, please study the router setting of Cable Modem which referred to router's user manual.
Posted on Apr 22, 2013
Problem cisco EA6500 to i-cable router HK
Apr 21, 2013 | Cisco Linksys EA6500 Smart Wi-Fi Dual-Band...
The router is saying there is no internet connection from the router to the modem.. Please help cause i have internet from modem to computer..
That means that the communication is cut from router to modem. You need to find out what is the problem.
1. check if the network cable from is still working or properly connected2. try a different ethernet cable or network cable from router to modem3. try some other dsl ports (yellow ports) at the back of your modem for ethernet cable connection to the router.4. switch ends of the cable you are using
these steps should fix the problem for if you are going to analyze, the line break comes between the router and modem and the only means of communication of your router and modem are cable, modem port (for the network cable) and router port (for the network cable) which means that the problem is within that point only. This should fix the issue.
Dec 28, 2011 | Linksys Wireless-G WRT54G Router
How do i hook up a wireless router to a cable router
If you already have a cable router, then you don't want to use a wireless router. You will want to use a wireless access point instead.
The reason for this is that anything plugged-in to your cable router will not be able to access anything connected to the wireless router due to the NAT firewall in the wireless router.
If the wireless router has the option to make it a "Gateway", then that will fix this issue; otherwise, take the router back and buy a wireless access point instead.
As for how you hook up the wireless router to the cable router, you have to unplug the power cord of the cable router for about 15 minutes before hooking the Ethernet jack from it to the wireless router.
Once the 15 minutes have passed, you then can plug the Ethernet cable from the wireless router "WAN" port into an Ethernet port on the cable router and then plug-in the power cord of the cable router.
Once the cable router is finished syncing-up, the cable router should provide an IP address to the wireless router.
If you really have a cable modem instead of a cable router, then you won't have to put the wireless router into gateway mode.
Dec 30, 2010 | Linksys Wireless-G WRT54G Router
Can I use USB Cable direct to laptop from modem? Ethernet cable from modem is connected to router which is connected to desk top PC. OR should I connect a ethernet cable from router to laptop? Type of...
Hi Friend, It depends that whether your router is wireless or wired. If it is a wireless router then there is no need to connect the laptop with the cable, you can use the laptop wirelessly If it is a wired router and as you said that the Desktop is already connected to the router with the cable so in that case you have to get another ethernet cable and can connect it from the router to your laptop
Dec 08, 2010 | Computers & Internet
Changed from DSL, to cable no router connection
1. You need to make sure that you have a "straight through" cable and not a "crossover".
2. the yellow cable that your cable company provided is the cable that goes from the rj45 wall connector to the "WLAN" connector in the back of the router.
If you go to router manufacturers site you will find the instruction how to to connect your router to the cable modem.
3. check also the firmware updates for your router at this site and download.
4.Use your setup disk and follow the instruction set for cable also. This should walk you through the proper setup .
YOu didn't provide the model number of your router, I would have given you the setup site for your particular router.
You can go to D-Link's site and download the PDF instruction also.
May 15, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cannot connect to internet using wgr614 router. connection is good without router. with router connected, internet lite blinks.
To use a router with a DSL modem or cable modem, you need to connect the modem to the router at the WAN port and then connect the PC to one of the router ports. If the cable you have been using between the modem and PC is lableled as a cross-over cable, it is the wrong type of cable for the router connection. Use a straight through cable to connect the modem to the router.
If you do not have a manual for the router, here is a link to the router manual online: http://kbserver.netgear.com/pdf/wireless_router_setupmanual.pdf
The cross-over cable could be the problem (typically yellow cable).
Jan 20, 2010 | NetGear WGR614 Wireless Router
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Netgear wireless modem router dg834g i have no disc with router also im on cable moden how do i change it over
ok... you ned assistance... the modem connects to the router... if you look at the back of the router it should say internet. thats where you connect your modem to. then everything goes through your router...email me and I will try and assist
Jun 21, 2009 | NetGear DG834G Router
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys by Cisco Linksys EA6500 Smart Wi-Fi Dual-Band AC Router with Gigabit and 2x USB Logo
81 people viewed this question
Top Linksys by Cisco Computers & Internet Experts
ka4iup
ka4iup
Da Doc
Are you a Linksys by Cisco Computer and Internet Expert? Answer questions, earn points and help others
