Question about Kirby Vacuums
My kirby upholstery shampooer doesn't work right
It is supposed to extrude suds, but I just get soapy water
  • Kirby Master
  • 18,424 Answers
Are you mixing it correctly this link below may help you
http://www.goodvac.com/Articles.asp?ID=153
Posted on Apr 21, 2013
5 Suggested Answers
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
  • 3 Answers
SOURCE: where does the carpet fluffer to on the kirby shampooer
you remove the 'vacuum' head and use the same one as for the shampooer (on mine at least)
Posted on May 18, 2009
b0sslady2001
  • 357 Answers
SOURCE: Foam stopped working on my Kirby shampooer
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose.
Marci
Posted on Jun 28, 2009
b0sslady2001
  • 357 Answers
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
May 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Shampoo does not sud
The suds screen is not there or is somewhere in hose elbow. Click HERE and read the tip about installing the suds screen.
If you want to see where the screen is supposed to be installed - see out Kirby shampooer manual HERE.
Good Luck
Rocky
Apr 03, 2009 | Kirby G6 Bagged Upright Vacuum
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby Ultimate G Series. I have misplaced (no, it's not lost...I have it somewhere) the manual. How do I use the upholstery attachment? Does it hook to the outlet on the shampoo tank?
Hope this helps!!!
Feb 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Shampo system
here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Feb 03, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby shampooer
You may be missing the small round suds screen. It should cover the hole where the shampoo goes from the tank into the hose. It may be wedged sideways in the hose end.
Marci
Sep 13, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
35 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
