Question about Rockwell RK7240.1 10-Inch Portable Table Saw with Stand
Replacement fence for rockwell table saw mdl. rk7240.1
When I tighten the fence the far end "kicks" to the right from perpendicular ... andy suggestions?
This is not an uncommon problem.
Personally, I measure the desired width of cut from the edge of the blade to the fence, then back from the fence to one of the slots in the table deck. I then use that measurement at both ends of the fence.
That way the fence is exactly square to the table. Takes a couple of seconds to set up but it is very accurate.
Here's a link to a forum discussing the problem.
http://www.ncwoodworker.net/forums/showthread.php?t=50795
Hope it helps.
Cheers
Feb 10, 2016 | Rockwell 34-348 Table Saw 10"
I need a fence for a Yuan Huey (Sakura) table saw, model YHS-258AO. Any idea where I could get one?
I don't know of a source.
Table saw fences/rails are often interchangeable between table saw brands. Usually the rails that the fence rides on must go with the fence. The simpler the connection, the more likely a transfer is compatible.
Sep 30, 2014 | Saws
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
Sep 13, 2013 | Delta Rockwell 34-450 10" Tilting Arbor...
Rip capacity is too small (24
If you can locate an old Delta Fence, I have seen those transplanted to a number of other table saws quite easily and reliably.
Otherwise aftermarket, there is the Beismeyer fence, it was adopted by Delta and licensed. You can get them through Delta or even Amazon. There are other vendors. You will want to add outfeed tables and extension tables as well.
You did not indicate which saw you have, but in general terms this applies to most saws.
Feb 14, 2012 | Saws
I have a crftsman table saw mdl # 137228210 I purchased the saw used. I need a rip fence . the guides are allready there. any help would be appreciated
There's an exploded parts drawing and parts list at the link below. This may be useful to see what the fence is supposed to look like. It's not listed as an assembly, just a surprisingly long list of parts that would cost a fortune - if they were all available. Maybe you can find one on ebay. Barring that, you can always just clamp a board to the table to rip with - the hard part is getting the makeshift fence to be parallel to the blade. To do that you can use an adjustable square and measure from a miter slot in the table to get a quick and straight setup. Good luck.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137228210/0247/0744600/P0104056/00001?blt=06&prst=0&shdMod=137228210#Partslist
Feb 09, 2011 | Craftsman 10" Table Saw
I have just purchased a Delta Rockwell Industrial Table Saw. It is a 1.5 HP, 3 BELT, 3 PHASE UNIT. How should I clean and lubricate the parts. I also bought 22OV 5 HP motor to put in it because I only have...
The table can be cleaned and waxed with a good quality paste wax like Trewax clear. If it has rust, you can use automative polish/cleaner and a rag or fine scotch pads to get the rust out, then wax the surface to protect it. Period waxing will maintain a low friction surface through use. Old timers used to recommend rubbing the bare steel table with talc to seal the pores, but I find was is more readily available and gives a better surface for use...Wax is also good on the moving parts of the fence.
The worm gears and trunnions can be cleaned with compressed air and regular 30w motor oil in a pump can. Maybe a soft wire brush or toothbrush if needed to remove built up resin and pitch. If there's a really heavy build up on the gears, get some OxiSolve bit and blade cleaner from Woodworker's supply and it will safely dissolve the gunk to a consistency you can scrub off with a toothbrush. I maintain these moving mechanical parts with oil, which an old pro recommended years ago, and have found it doesn't contribute to sawdust build up as you think it might, not nearly so much as an assembly lube or white grease, and makes raising and lower the blade a joy. If you're concerned about dryness, you can try triflow or some kind of bicycle chain lube, but I've decided the expense isn't worth the results, and oil is readily available when I need it...
If replacement parts are available for your model, try here. Otherwise, and for older machines, you might find a manual or parts info at this site.
After market fences are available for your saw, and depend on user preference. I've been very happy with my Biesemeyer fence, after using it (and many others) for 22 years. It is also heavy duty.
Jul 18, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Manual,fence and rail
The manual doesn't seem to be available online at the moment. There's a parts diagram, if that's helpful, or perhaps you can find an alternate site that provides instruction manuals. See this link, in any event.
Otherwise, you might check Woodworker's supply (woodworker.com) for the accessory fence and rail. They carry genuine Delta parts, which should fit your old Rockwell, as well as some aftermarket fences and guides that will usually adapt easily to fit a 14" bandsaw. The 14" Rockwell is one of the industry standards, and many woodworker catalogs carry fences that will bolt on with a minimum of fuss.
I recommend you do a web search on "14" bandsaw fence", and browse the results. You may even find something used to suit your needs.
Good luck, and let us know if this solves your problem or we can provide any further information!
Mar 23, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Manual & fence system
I would contact the nearest Rockler woodworking store. they have or can get it for you.
please mark this as a fixya!
Mar 12, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
Rockwell RK7240.1 10-Inch Portable Table Saw with Stand Logo
105 people viewed this question
Top Rockwell Saws Experts
Tom Chichester
ray gallant
Are you a Rockwell Saw Expert? Answer questions, earn points and help others
