Question about Toro 14 in. 5 Amp Corded String Trimmer 51480
Toro 51480 would not run
It's the electric, corded version. It just stopped working 5 minutes into sing it. Ideas? The manual that came with it s worthless - no troubleshooting whatsoever
  • cstefanescu
    cstefanescu Apr 24, 2013
    Any ideas? Are there any troubleshooting manuals you are aware of?
  • 4 Answers
SOURCE: My Toro Super Blower works fine & then I notice smoke at the cord
sounds like your blower is drawing to many amp`s for the cords your using for this
Posted on Feb 13, 2009
  • 33 Answers
SOURCE: Toro lawn mower sputters and stops working after running
fuel delivery probblem might be vapor lock(to much heat getting to fuel lines and carb) may also have dirt in fuel bowl on carb and in tank ,gas tank lid may not be venting . it will be one of these three things
Posted on May 02, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
SOURCE: electric starter not working on Toro
I've had the same problem (I think) - the starter will not activate. First time, I found the fuse that's attached to the battery "tray" had corroded. For that I put a good coating of silicone dielectric grease on the fuse contacts and holder. This keeps moisture out. With that it was good for a few months. Now it's gone bad again. This time the fuse is good, but the battery is dead, and so dead that it won't recharge. Apparently the cause of the discharge was/is grass and moisture finding its' way into the battery area, and providing a conductive path between the battery terminals. I was recharging it regularly, following the owners manuals' instructions, so it's definitely not a negligence problem caused by me.
So, obviously what we have is a design flaw in the mower that allows grass clippings to get into the battery area. Time for a recall, but for a quick fix for your current pioblem, you might just find the fuse is corroded, and a replacement + non-conductive grease may be all you need to git'er going.
Posted on Nov 05, 2009
rycgl
  • 1545 Answers
SOURCE: Toro snowthrower model 38185, wont
For the easiest solution, try running some automotive type fuel system cleaner through the machine (added to the gasoline; not straight). Find some Chem Tool Berryman B-12 at the auto parts store and add 2-3 ounces in a gallon of fuel or 1-2 ounces in a half gallon. The solvents in the cleaner may aid in cleaning a dirty carburetor. You may want to drain the fuel and remove the carburetor bowl and clean it out as debris may be there, intermittently clogging up the main jet in the carburetor. Water will settle there too.
Posted on Jan 09, 2011
Toro gts 6.75
you will probably need to replace the tabs that pop and grab the fywheel, the springs should be replaced as well.
Jun 15, 2013 | Garden
Trimmer works sometimes and other times it won't. When it works it is only for a few minutes then it stops like a switch was shut off.
Sounds like fuel issue. Check the fuel line for cracks. Also the diaphrams in the carburetor could be deteriorated due to Ethanol. Soak and rebuild.
Sep 16, 2012 | Toro& Electric String Trimmer
Toro pull cord won't rewind
You have to open up the starter and reattach the spring that works with the pull cord. A royal PIA.
Sep 16, 2017 | Toro Personal Pace CARB Walk Power Mower
Toro model 20581 that was made in 1988 .
dump out the old gas and use fresh fuel gas is only good for 30daye in small engines if you did that remove the muffler and run it if ok open the muffler and clean the carbon build up from the screen
Apr 12, 2012 | Toro Lawn Mower With Toro Power Tools
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
How do I replace the line in an 11 inch electric toro trimmer I can't turn the part that would come off to put new line in.
All I can do is refer you to the manufacturer's instructions. See page 5 after downloading your user manual. If you can not turn the cap off, then the cap is possibly cross threaded onto the shaft end and/or the threaded end if the driveshaft is stripped. See if the user instructions are of help to you.
http://www.toro.com/en-us/Homeowner/Yard-Tools/Trimmers/Pages/Model.aspx?pid=51347-11-Inch-Electric-Trimmer
Jun 08, 2011 | Toro& Electric String Trimmer
May 01, 2009 | Toro Lawn Mower With Toro Power Tools
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Feb 13, 2009 | Toro Super Blower Vac
Toro 14 in. 5 Amp Corded String Trimmer 51480 Logo
50 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
