Question about Whirlpool Kitchen Ranges
GW395LEPB00 f2 code, oven will not bake
SOURCE: Oven trouble
Do Not try to perform the below if: Oven is under warranty,You are not handy with a soldering gun, or Are afraid to do this.
The below solution applies only to my in-wall oven with F2 and F3 codes randomly, but presumably will work with other GE models.
I had the same trouble with a GE in-wall oven. The problem was on the electrical board behind the keypad. A pin that was soldered to the board, that was the input for the oven temp sensor, had cracked solder. So I re-soldered the pin and hopefully it will continue working.
If this fixes your oven please post back!
Posted on Dec 21, 2007
SOURCE: Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Posted on Apr 04, 2008
  • 38 Answers
SOURCE: EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Posted on Nov 02, 2008
SOURCE: F2 amana acf4215ac
amana oven does not comeon
Posted on Dec 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: baking cake and F2 signal
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
Posted on Jul 25, 2009
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
ACCU BAKE codes come up e6 f2
You have the following error.
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore Ovens
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F2 :-
F3:-
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
26 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
