Question about Dishwashers
Why is the maytag reservoir always full - Dishwashers
  • Dishwashers Master
  • 16,166 Answers
Most likely the drain hose or sump area / pump are plugged. See if you can locate the hose and use a wet vac to see if you can draw the water through it. If that does not work you can back flush it with a garden hose.
Posted on May 04, 2013
How do you adjust the water level
After the first brew the machine should brew excactly the amount of water added to the water reservoir. Since the reservoir always keep half full then you should add the maximum amount you need in two steps.
Apr 07, 2012 | Grindmaster B-SAP Coffee Maker
Dehumidifier indicates that it is full even though it is not
Look inside where the water reservoir sits, you should see a small float. This float triggers a switch that shuts the unit off when it gets full. You want to make sure that float is able to move freely (not caught up on the edge of the reservoir), and that it makes a "click" sound when you lift it up. If it's moving freely, but the unit still thinks it's full, you may have a faulty switch.
May 02, 2011 | Maytag Dehumidifiers
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Change my dehumidifier from draining by hose, to reservoir
I don't have the exact dehumidifier as yours, but on mine it's as simple as removing the hose, then the water fills the reservoir. Does it look like yours will do the same? If so, the hose fitting is also a sensor that will shut the unit off when it is full to avoid leaking onto the floor.
Sep 11, 2009 | Maytag M3DH30B2A Dehumidifier
Need manual with exploded diagram
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(866)616-2601 U.S.
(800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Maytag M7DH45B2A Dehumidifier
Radiator coolant or reservoir tank always full
Relax, there is no problem.
When the water / coolant gets hot (inside of radiator/engine) it starts to boil, ofcourse when it boils, it expands, so the fluid in the radiator has to go somewhere, thats why there is the overflow reservoir. So, when the fluid boils, some moves to the reservoir to avoid any potential problems with the radiator, such as it blowing up, or not being able to cool off all of the fluid running through the engine.
But relax, its normal.
Jul 13, 2009 | 1993 Mazda 323
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Pathfinder Window Washing Fluid not Spraying
Check for any vacuum leaks near the fuel system. be careful to notice where you removed the hoses from. check the windshield wiper motor by jumping it from the battery. be careful not to touch any ground wires with the positive.
Dec 25, 2008 | 1994 Nissan Pathfinder
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
