Question about HP Color LaserJet 5550dn Q3715A Workgroup Up to 27 ppm 600 x 600 dpi Color Laser Printer
No display in control panel
Im troubleshooting hp color laserjet 5550n and the problem is no display in control panel. I dont know if the printer is initializing and one proble also when I turn on the printer all LED are in solid light...
Can you help me to solve this problem?
thanks...
Had this problem after a power hiccup. The firmware on my HP 5550 / 5550n has been a problem in the past, needing updating or currupting, but this time I was getting the power on, a backllit control panel but no menus or text, and steady on READY, DATA and ATTENTION lights. At any rate I saw a solution on the Internet and owe that poster a beer if I can ever find him.
All things led to a corrupt Firmware. Problem and most beleieve you have to send for a new Firmware FlashCard and that takes time and big $$$. I found that if you can find another working 5550 / 5550n you can pop it's firmware FlashCard, make an image of it, and restore your own firmware to a working state.
The 5550 /5550n printers firmware resides on a 32MB Compact FlashCard on the printers Formatter Board. (The formatter board is held into the printer by 8 screws, and also has the JetDirect card on it.). This Firmware FlashCard when removed, will fit in a standard Compact FlashCard reader, and can then be attached to any Windows Machine for manipulation.
NOTE that this Compact FlashCard containing the printers firmware involves a proprietary HP created partition that a Windows PC cannot even read. Thus when connected to a Windows PC you'll see nothing, and may well be challenged to format the card!!! --- Obviously... DON'T DO IT !!
There is a FREE program called SelfImage available. Just Google: download SelfImage. The pesent version of SelfImage as of this writing is v1.2.1. It can and will see the contents of the FlashCard, and thus can make an image file of the FlashCard for use down the road. Should the firmware on the CompactFlash Card ever get corrupted, you can restore it from any image file by simply using the SelfImage program in reverse.
I made two image files of a good firmware flashcard from a working 5550 / 5550n because when you choose to make the backup image in this SelfImage program, you can do either the entire physical drive, or just a selected partition of a physical drive. In the case of this printer's firmware FlashCard, the drive and partition appear to be one in the same, as will be evidenced by the exact same file size of the resulting images. I made copies both ways (drive and partition) just be sure all possibilities were covered.
I now make copies of that Firmware everytime it's upgraded.
Posted on Jul 03, 2012
  • Steven Heaton Mar 03, 2013
    Excellent post. Could you post a copy of the firmware please?
  • Alex Gerasimoff May 23, 2013
    Hi there! Could you share your 32M image of firmware with me please? Got totally stuck after loading it via lpt.
4 Suggested Answers
SOURCE: Color Laserjet 5550n 59.0 error
How to solve 50.0 error for HP 5550n
Posted on Apr 24, 2010
seeker5211
  • 1089 Answers
SOURCE: How can I solve the
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Posted on Feb 18, 2011
FixinFax
  • 3085 Answers
SOURCE: HP Color laser jet 5550n does not print in
Uncheck the PRINT IN GRAYSCALE box in Printer Properties.
Posted on Jul 06, 2009
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
How to cold reset
http://www.ehow.com/how_8337650_do-restart-color-laserjet-3600n.html
Instructions <:section>
    • 1 Turn the printericon1.png on and look for the control panel display to count the memory. When the memory count begins press and hold the green "select" button located on the front of the printer. When all three of the front control panels LED are lit release the "select" button.
    • 2 Press the "Down Arrow" once when you see the "Select Language" display. Press the "Select" button until your controlicon1.png displays "Cold Reset."
    • 3 Press the "Select" button and your printer will initialize a cold reset.
Jul 01, 2014 | HP LaserJet 3600n Printer
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
When printing from computer and selecting tray 2 with 8.5x11 in it, if Tray 1 (Manual Feed) is in the down position with 11x17 paper in it the 5550n will automatically feed from Tray 1.
look at the tray settings on the printer, (Access the control panel) typical setting is "any size any type", change the tray 1 setting to 11 x 17 , plain paper, and it will then take the paper as requested.
Jan 11, 2011 | HP Hewlett Packard LaserJet 5550n Printer
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
How do I set my 5550n printer to print only black and white copies and color on demand?
If you go into control panel then go printer options you should see your printer icon. Right click on it and go printer preferences or printer properties and I think there is a colour tab where you can set it to just back and white
Sep 22, 2009 | HP LaserJet 5550n Printer
What make of printer are you talking about? If it is HP then please go to http://www.hp.com .
Jun 10, 2009 | HP Color LaserJet 5550hdn Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
HP Color LaserJet 5550dn Q3715A Workgroup Up to 27 ppm 600 x 600 dpi Color Laser Printer Logo
1,425 people viewed this question
Seeker5211
Seeker5211
