Question about Honeywell Ademco Vista 15p With 6150rf Keypad Wireless
Can i use the 6150rf keypad to program a vista 15p
  • Steven Wilson Sr
    Steven Wilson Sr Jun 15, 2017
    You will need a 6160 or 6160rf to program all fields in a Vista 15P. A 6150 series will not program the zones and a few other fields.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Contact honeywell tech support
Posted on Dec 18, 2014
3 Suggested Answers
steve_hillin
  • 44 Answers
SOURCE: 6160 key pad "open circuit"
This could be caused by a mis-wired zone on the control panel. If there are any unused zones on the panel, and/or if the bell circuit is unused, a resistor ( info in installation guide ) must be used across the terminals or you will get an open circuit message. If you can't see it straight away, have your local alarm company check your system and they can find this fault for you quite easily.
Posted on Mar 05, 2011
  • 20 Answers
SOURCE: I have just fired up
Your keypad needs to be addressed. Within 30 seconds of powering up the panel, go to the keypad and hold down the 1 and 3 buttons. Address 31 will pop up on the display. Push 1 then 6 then *(star).
That should do it. The address may pop up with a different number than 31. As long as you address it to 16 you're good to go. Address 16 is the default address for the first keypad on the system.
Hope this helps.
Posted on May 16, 2011
Vista 20p momentary sounds alarm when system is armed why is this?
It can be disable in installer level programming. It is called confirmation of arming ding. It is so you know that your system is arming when you use you keyfob from outside of your house.
Mar 04, 2014 | Honeywell Ademco 6160 Alpha Keypad Vista...
What is a long range radio trouble
It indicates a problem with your cellular radio or that your alarm system is programmed to look for one that is no longer working or connected to your system. This can be disabled in installer level programming.
Aug 21, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell ADEMCO 6150RF keypad sporadic constant beeping
It is trying to indicate a problem with zone 1. check it out.
Jul 25, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
Can't access installer code honeywell vista 20p
Power down the panel, remove the battery. Hold down the * and # while re-powering the panel. It will jump right into programming. Release the *and # button and proceed with programming.
Apr 07, 2013 | Honeywell Ademco 6160 Alpha Keypad Vista...
Only 12 wireless zones 6150rf
The E8 Means to-many zones for you 6150rf to handle i suggest replacing to a 6160rf
If you need further help, reach me via phone at https://www.6ya.com/expert/joshua_f823c77053c73844
May 12, 2012 | Honeywell Ademco Alarm 6150rf Keypad Lk
How do i program the 6160 keypad?
In order to add a user code, you first need to know a master code.
Feb 03, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell vista 20p FC error code no monitor service beeping every 30 sec. need help how to stop beeping
If the keypad displays FC, that means that it is programmed to send alarms to a central station and a phone line isn't connected to the control panel. If you do not subscribe to monitoring services, it will have to be re-programmed. I can do that for you over the telephone if needed.
Thanx Mark Garrett
Aug 21, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
I have just fired up my Vista 15p panel and my keypad has power and is backlit however I am not getting any text on the keypad. I have checked and double checked and the wiring is all to the spec. sheet....
Hope this helps.
May 16, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell Ademco Vista 15p With 6150rf Keypad Wireless Logo
272 people viewed this question
Top Honeywell Home Security Experts
Steve
Mike
Are you a Honeywell Home Security Expert? Answer questions, earn points and help others
