Question about Car Audio & Video
Instead of milage active fault 1 is displayed as well as stop eng indicator light on 98 freightliner n14 automatic
Well if it is jensen or phase linear cut the pink wire it should work wile driving -I think it is indusrty standards that all manufactuers use the same color code
Posted on Mar 13, 2009
2011 Dodge Dakota Lonestar.Battery drains dead in 6-7 hours.
Sounds like a [i]possible[/i] short in your wiring loom / harness.
Get an auto electrician to go through your wiring system.
From a first-hand incident, an unattended short [i]could[/i] result in burning wires / fire.
Apr 08, 2018 | Dodge Cars & Trucks
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
Whirlpool Cabrio he washer stopped in drain and spin cycle. Won't drain or spin. drain hose seems clear. Powered off for a few minutes. When I powered on and pushed "start" it poured water in...
You may perform an automatic diagnostic test to check the machine functions and view any saved fault codes. Fault codes may also appear during the test when a problem is detected. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on). Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):
If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
The program then automatically checks for saved fault codes. Record the fault codes and post it back.
Press the same button used above in activating the test to advance through the automatic test steps. The basket must be floating in order to agitate. Allow step C1 to complete before advancing to the other steps. Record any fault code shown during the tests and post it back including which step the code is displayed.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Jul 20, 2011 | Whirlpool Cabrio WTW6800W Washer
Fix revers in automatic Freightliner Truck
Which transmission you got. Zf meritor or ultrashift?
Feb 19, 2010 | RTO Ho Herpa Freightliner Truck Tractor
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
F1
jenkle, F then 1 flashes when there is a primary control failure. There is a couple of things you can try. 1. Unplug the machine for 2 minutes and see if the error returns. If it does, try activating the auto diagnostic mode. With the washer plugged in and all indicator lights off, select any key except power, start and stop. Here's what you do; press/hold for 3 seconds, release for 3 seconds, press/hold for 3 seconds, release for 3 seconds, press and hold for 3 seconds. If you did it right all indicators will light and 88 will appear in the display. If there are any faults, they will then display, look for a F-60 through 68. This will confirm the board is corrupt. If no faults are found the machine will go through a five minute automatic test cycle. To stop the test, just press stop/cancel. Check your owners manual and see how long the board is warranteed. Catriver
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Car Audio & Video Logo
398 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
