Question about Bosch B26FT70SNS
Bosch ice maker off on switch will no stay on
On off switch for ice maker
The wire arm that travels up ad down when it dumps ice. Lift the arm to the horizontal position and it should stay there. The ice maker is now off. Push the arm back down and the ice maker is on.
Mar 01, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Bosch ice maker
If the compressor is running, the freezer fan should be running.
Sep 21, 2017 | Refrigerators
Ice maker water volume
When you open the Freezer Door, There's a Square Button "inside" the ice maker door compartment.. You'll see the White machine area of the mechanics of the ice maker in front of you. Place your finger under it towards the Left and Press! This will cause the Ice Cubes to fall out .. My "teen" nephew discovered it while staying with us over a summer! How much you wanna bet Bosch knows about this issue & still wants us as unknowing consumers to pay? Horrible!
Sep 15, 2012 | Bosch Evolution 500 B20CS50SNS
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
Ice maker will not shut off when full of ice.
There is usually a bin switch with a probe that is in the bin, when the ice covers the probe, the switch opens shutting down the machine, as you remove ice and uncover the probr the switch closes and the unit starts. Check the switch for continuity, its probably staying closed thus keeping the unit on
Aug 31, 2011 | U-Line Icemaker
Have had Bosch refrigerator for about three weeks - love it - but, after about three days it started clicking or knocking - did this for about thee days and stopped for a week - now it is doing it again...
Well one of two things ,first is it could be the ice maker and those pops are the ice coming off the rack which I suspect and the other is a relay clicking coming in and out of defrost cycle for the ice maker. Get enough ice made and have the switch in the up position and see if it stops, if not try and locate it and tells us again
Apr 08, 2011 | Bosch B36ET71SNS Bottom Freezer French...
How do I unlock the ice-maker panel?
Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
Bosch Evolution B20CS50SNS about two years old. No ice is dispensed. Looked inside and tray is frozen over solid. Also looks like water has overflowed and frozen down in bin. Could not figure out how to...
I've had lots of problems with my Bosch refrigerator ice maker. The ice tray has a tab on the back corner that twists the tray when it cycle to empty the ice. That tab broke off and when I looked into replacing the ice tray the authorized Bosch dealer said the tray is only sold with the complete ice maker unit. Sells for about $160. I have a hard time spending $160 for another complete ice maker when I only need a $10 replacement ice tray. This ice maker is sub-par for an appliance name brand like Bosch.
Dec 08, 2009 | Bosch Refrigerators
Ice maker not working bosch refridgerator
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Sep 20, 2009 | Bosch Evolution 500 B20CS50SNS
Ice maker not ejecting ice and then tries to fill tray and leaks
The Ice Maker Tray had a small plastic piece break off. This piece aids the tray in bending to dislodge the ice from the tray. Bosch does not just sell the tray, you will have to buy the whole ice maker assembly. You will need to order Part # 0422 from Bosch. I was not very happy about having to spend $112.00 for this whole assembly when all I really needed was a simple ice cube tray.
Save the $112 and remove the ice maker. Buy Ice at the grocery store.
Mar 31, 2009 | Bosch Evolution 500 B20CS50SNS
Bosch B26FT70SNS Logo
151 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
