Question about Maytag Dryers
Pyg4557aww won't start
  • Ryan Apr 21, 2013
    Sorry my description was not good. Here is what I have going on - the dryer worked fine, and then it didn't. I took it apart, cleaned all I could and it worked again! I was happy...and then a few loads later it stopped working again. So here is what I have now - when I press the timer button (or on any setting) I hear a faint buzz, but the dryer will not turn. I have been successful one time by helping it to turn counter-clockwise...but only once. I have taken off the thermal limit/fuse and tested it with a meter and it works. I also tested the high limit and it works. I am not able to turn the drum clockwise very easily at all. When I turn it counter clockwise the belt is not turning with the drum. I am not sure about the blower...it was full of lint (like you said) but it is difficult to turn also - but when I do turn it, the entire drum moves. Thanks for any help you can offer!"
  • Maytag Master
  • 8,220 Answers
Fuse is located on the right hand side of the heater element. Check the blower, if it is loose it will overheat and blow the fuse on this one. To get into the machine you work from the front only. The backside cannot be accessed. Unplug the machine. Use a thin blade or putty knife to release the top.
So if the door switch is ok, the thermal limit/fuse will most likely be the problem. The cycling thermostat is what controls the heat. As air is drawn into the blower from the drum is shuts off the heater at around 155 f. when the temp drops to 105f it powers up the element again. So what goes wrong? That plastic blower wheel wears out and blows but not enough, a big ball of lint builds in front of the blower. The base of the filter chute gets clogged, all of the above. This makes the 250 degree stat cycle, eventually it won't be quick enough and the small dime sized fuse mounted beside the heter blows or trips. She at that point becomes dead in the water waiting on a good cleaning and inspection. This is one of the easiest of all the dryers to repair and is well worth fixing. It is better than any of the junk on the market today.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 21, 2013
Testimonial: "This was very helpful - sorry my description was not good. Here is what I have going on - the dryer worked fine, and then it didn't. I took it apart, cleaned all I could and it worked again! I was happy...and then a few loads later it stopped working again. So here is what I have now - when I press the timer button (or on any setting) I hear a faint buzz, but the dryer will not turn. I have been successful one time by helping it to turn counter-clockwise...but only once. I have taken off the thermal limit/fuse and tested it with a meter and it works. I also tested the high limit and it works. I am not able to turn the drum clockwise very easily at all. When I turn it counter clockwise the belt is not turning with the drum. I am not sure about the blower...it was full of lint (like you said) but it is difficult to turn also - but when I do turn it, the entire drum moves. Thanks for any help you can offer!"
Whirlpool WGD6200 won't start
When you say it won't start, do you mean it won't heat up or do you mean it won't spin?
Nov 07, 2012 | Dryers
When you push start button nothing happens
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My 4 runner starts sometimes and won't other times, it justs cranks over but won't run
As with any no start issue, you will need to check for spark and fuel pressure when it won't start to know how to proceed.
Aug 19, 2012 | 1997 Toyota 4Runner
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Replace starter and battery 1999 Mazda 626 still won't start
Won't start or engine won't turn over and try to start?
Aug 06, 2011 | 1999 Mazda 626
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
Maytag dryer PYG4557AWW
sounds you have a gas issue for sure, did you recently change from nat gas to bottle gas??? is this a new purchase??? sounds as if your burning a natural gas setup on lp gas call back the installer if thats the case
Mar 13, 2008 | Maytag PYG4500A Gas Dryer
Dryers Logo
69 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
