Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Affter cleanning the opctical block the images no clear hav three colors sony grand wega kdf 55wf 655
My english is very bad but im try to explain the situation affter reconect all wire and return to the position the optical block suppost corerect now the image precen no clear images and three color how fix the situation
bluenadas
  • 203 Answers
SOURCE: Growing Blue Color
It's most likely the light engine. Sony has a service bulletin on these right now for one of the causes of this. Both causes result in the replacement of the light engine but they are only covering one type.
Posted on Jun 08, 2007
circuitcity
  • 137 Answers
SOURCE: Sony Grand WEGA KF50WE610 50 no red color
Check and replace your component cable wire (Red,Green,Blue). This is a very common problem with these component cables
Best regards
circuitcity
Posted on Dec 09, 2007
ctf1800
  • 4402 Answers
SOURCE: Sony Grand Wega KDF-E050A10
Authorized sony repair center told me the problem was the Q Box. Ever heard of this? Part runs about 300 bucks. TV is out of warrenty as it is 2 years old. Do you think it is worth it to fight sony and get them to replace the part or just fix the TV?
Part Number is A1167541A, service rep called it a Q Box in the diag, however the web says its the b block assmy.
read this if you think it's the same problem
Posted on Feb 01, 2008
SOURCE: SONY GRAND WEGA KDF-60WF655 - VERTICAL LINES
check standby power supply caps (elec. type probably swollen) after that then it's the q box
Posted on Jun 29, 2008
  • 668 Answers
SOURCE: sony xbr 60 grand wega color problem.
It sounds like to me you have a bad Optical Block. It is a expensive repair and you may want to call Sony at 1800-222-SONY and see if the would assist you in repairs. Due to the age of it, they would probably only cover a partial amount of the repair.
Hope this helps,
Skyassoc
Posted on Jul 25, 2009
No colour in bottom right corner
I believ you have an issue with the optical block on your set. Light produced by a high-intensity projection lamp enters the optical block and is split into three paths (one each for red, green, and blue) by a series of lenses, condensers, mirrors, filters, and/or beam splitters. Each color has an LCD assembly with polarizing filters and a liquid crystal microdisplay panel (approximately 1" across). On Sony's "3LCD" models, the light is transmitted through each LCD panel, and, on their "SXRD" (Silicon X-tal Reflective Display) models, the light is reflected off each SXRD panel. Finally, the three separately colored images are combined with a special prism into the final full-color image, which is then projected/enlarged onto the back of the screen by a projection lens.
The following annotated photo shows various parts on the optical block of a 2004 3LCD model KDF-55WF655 (note that the LCD panel cover has been removed):
dcramer531_82.jpg3
Either the block is starting to wear out or you have something blocking the lens, such a dirt or something has fallen and is blocking the lens
Feb 20, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand wega kdf 60xbr950 purple stain on the screen
Is very likely that the lamp will need to be replace soon.
Is some cases those spots might be generated in the inner part of the lamp.
Apr 27, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My Sony Wega rear projection TV has green
I hate to tell you this but if your light enginge /optical block is bad you are Looking at just for Part $1,949.95 core refund is $1,300.00 Then part is 649.95 Encompass Parts Distrubtion has 23 of them
1-800-638-3328 Chances are it is your Light Engine!
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
How do i install a replacement xl 2400 lamp within a housing unit into my sony wega kdf46e2000 tv??????
how do I REPLACE THE LAMP IN THE kdf-42WE-655 WEGA TV. i PURCHASED THE REPLACEMENT LAMP, PART NO. XL-2100U>
Sep 16, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kdf 50we655 color dot on black screen
a color dot is usually a bad light engine, you probably need to replae it, you can try taking it apart and cleaning all the dust out of it, this works sometimes.
Sep 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue dots blue line across bottom of screen
If your TV is DLP Sony Wega you have either dust/dirt on opitical lense of Light Engine or Bad Light Engine.You really do need to contact Sony they have updated warrranty on Certain Models Do to Alot of Bad Light Engines.
Aug 22, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
KDF-60XBR950 Grand WEGA
optical block bad please mark post as fixya!
2003-2004 Model Year Grand WEGA Televisions:
Models: KF-42WE610, KF-50WE610, KF-60WE610, KDF-70XBR950, KDF-60XBR950, KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620.
As technology evolves, Sony continually looks to stand behind the reliability of its televisions. It has come to our attention that a very limited number of televisions manufactured between 2003-2005, after a period of time exhibit a stationary scribble / random line pattern on the screen. Click here to see photos of this symptom.
As part of our commitment to quality, Sony is announcing that for any owner of this model television who paid out-of pocket expenses on or before May 26, 2006 for an estimate or repair service to replace the optical block for this specific issue, Sony will reimburse the customer by mail for his/her parts and labor expenses. To receive reimbursement, please follow completely the directions and terms on the claim form for reimbursement; all claims must be postmarked by May 31, 2007.
In addition, for any customer who later experiences this issue on one of the affected models, Sony will cover the cost of the optical block repair at no charge through September 30, 2007. All other terms of the Sony limited warranty continue to apply.
Feb 26, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
3 images in the primary colors
Your convergence amp ICs are bad they need to be replaced.
Feb 16, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
42 inch sony grand wega
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue shadow
You have a bad light engine or in Sony TV sets, it is called an Optic Unit Block Assembly. This is a very expensive part and should not be attempted to be replaced by a novice. Call an authorized Sony repair place to have this repaired. Good Luck
Sep 14, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
