Question about HP LaserJet 3050 All-In-One Printer
HP Laserjet 3050, need to press ok each time printing
Hp LaserJet 3050
Whenever I print,
"manual feed Letter, press (tick) for available paper"
I choose
Paper size - A4 &
Paper tray - Automatically Select.
Thanks in advance for your kind help.
Nang
  • 85 Answers
Did it work before? check paper size for trays - suspect it is set for a4, change to letter size
Posted on Mar 13, 2009
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P2055d Printer
When i send print appears in a printer press v to use availble media manual feed plain A4
The print job you are sending is in A4 format. If you are using Adobe Acrobat you will sometimes find that documents created in places such as Europe will be A4 not letter size. Check the settings when you send the print job as Acrobat gives you the option to resize and print to available media. You can also check your printer settings as there may be the option to automatically print A4 to letter.
May 23, 2011 | HP LaserJet 3050 All-In-One Printer
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Can't print
It means "manual feed".
Go in to the menu, under paper handling (i think) and turn manual feed "off"
Mar 27, 2009 | HP LaserJet 4 plus Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
Replacing Print Cartridge
Turns out there was an easy solution. I filed a support case and had an answer in half a day:
"Often this issue is caused by a sensor. â Therefore the first thing we should do is try to trigger the sensor.
1 Turn off the HP LaserJet 3050
2 Remove the toner cartridge from the HP LaserJet 3050
3 Remove all of the paper in the paper tray
4 Check the entire paper path for any obstructions
5 Reseat the toner cartridge and paper
6 Power on the HP LaserJet 3050
If the issue is still not resolved we will need to try some resets on the HP LaserJet 3050.
1. The first reset we can try is a soft reset, it is done by pressing the MENU key then holding *# together. â This will bring you into a Developers Menu. â Scroll through the options until you find reinit FFS and then press the ENTER key.
2. If this reset doesn't clear the issue we can try a harder reset. â We can do this by pressing MENU, scrolling over to SERVICE, pressing ENTER, scrolling over to RESTORE DEFAULTS and pressing ENTER to restore the defaults and ENTER to confirm.
WARNING: Restoring the defaults will clear your fax settings, phonebook numbers and headers so you may want to print a phonebook report and Config Report first. â We can do this by accessing the Reports menu.
3. If these two resets do not help there is a third reset we can try.This reset will completely put the HP LaserJet 3050 back to factory defaults.WARNING: Before doing this reset we will need to disconnect the power cord, the phone cable, and the USB cable from the back of the HP LaserJet 3050.We can do this reset by unplugging the power cord from the back of the HP LaserJet 3050 then holding down the MENU/ENTER key and * symbol at the same time,then powering the HP LaserJet 3050 back on with the keys compressed.We will release the keys as soon as PERMANENT STORAGE INIT appears on the display screen."
I tried all the steps in sequence; it took #3 to fix it. Fortunately I didn't have a big fax address book or custom settings, so a factory defaults reset didn't cause any extra problems. It retained the time and date, and now it works fine.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
I have to press the tick every time i print
If you go into the printer config there should be an option for "manual feed." Turn this off and it should fix your issue.
Feb 08, 2008 | HP LaserJet 2300 Printer
HP LaserJet 3050 All-In-One Printer Logo
1,331 people viewed this question
Ben Johnson
