Question about SkyScan 86709 Atomic Wall Clock
Where do i mount the outside temp sensor, - SkyScan 86709 Atomic Wall Clock
    Problem Solver:
  • 15 Answers
Outside!
Posted on Jun 05, 2013
The indoor temp on my acurite model 02086 weather stn. constantely reads 26c how do I get it to read the correct indoor temp?
The manual of unit will tell you how to change reading from Centigrade to Fahrenheit. Read it carefully for details.
Oct 02, 2016 | Measuring Tools & Sensors
The outside temperature gauge on a 2009 g5 Pontiac is not reading right how do you fix it
There is a outside temp sensor mounted on the radiator support in the front of the car,sensors get dirty or just fail
Dec 05, 2014 | 2009 Pontiac G5
2005 C230 Mercedes-Benz a/c temp. sensor location
Behind the front bumper/grille ahead of the radiator.
Dec 10, 2013 | Mercedes-Benz 2003-2005 C230 Kompressor...
Locate the temp sensor on 2004 chevy impala
I hate to tell you but there is more than one! One is the outside air temperature located in the grill that gives (supposedly) the temperature of the outside air. The other one is the radiator water temperature sensor that is located on either the right or the left side of the cooling radiator for the engine mounted in a fixture welded to that side of the radiator (the one with the wire coming out of it).
Jan 24, 2013 | Vehicle Parts & Accessories
Evacuated the system put new compressor with new clutch on the truck recharged the system pluged it compressor clutch will not engage but it will engage and blow cold air when hooked to the battery
inside the heater box there is a temp sensor it is actualy mounted outside the box about 1 inch high and 2inch wide with a long stem going into the heater box that sensor is what activates that clutch replace the temp sensor
Jun 09, 2012 | 1994 Ford F350 Crew Cab
Ext. temperature gage doesn't work on mercury montego?
Okay, the first thing is this may just be a bad sensor, the sensor is located on the front of the truck behind bumper area,Make sure the sensor is not unplugged or is touching the condenser or radiator. the sensor should be mounted so that it is not touching anything, the tip of the sensor is what reads the outside temp,
If the sensor is mount correctly and is plugged in then replace the sensor with a new one and that will solve the problem. good day.
May 06, 2012 | 2005 Mercury Montego
My outdoor air temp. reads -56 degrees when starting car, real air temp is 80, it keeps the a/c from turning on.
Hello, this is usually caused by a bad outside air temp sensor. the sensor is mounted behind the front grill, it has one connector with two wires pluged into it.
here is a picture of the sensor
Ambient Air Temperature Sensor Assembly
Jun 08, 2011 | 2007 Chevrolet Impala LS Sedan New Cars
Where is the external temp sensor on my audi a6 quattro
There is an outside temp sensor that is mounted in the front of the car behind the radiator grille. You should see a 1 pin sensor somewhere on the top of the radiator support.
Jan 13, 2011 | 2002 Audi A6
06 grand prix --my temp gauge is not working, the needle is flatlined. when i start the car the needle swings to the top but then buries itself at the bottom of the gauge. On my dash i have digital read...
Coolant Temperature Sensor I would take the vehicle back to where it was serviced and try to ask them about what may have gone wrong to cause this problem.
The Intake Air Temperature sensor should also be checked.
The following is the procedure for servicing the coolant temperature sensor: Removal & Installation 3.8L Engine To Remove:
  1. Drain the coolant.
  2. Disconnect the engine coolant temperature (ECT) sensor connector. ECT sensor 3.8L gm-04-38-4321.gif
  3. Remove the ECT sensor.
To Install:
  1. Apply thread sealer P/N 12346004 or equivalent to the engine coolant temperature (ECT) sensor threads.
  2. Install the ECT sensor. Tighten 18 ft-lb (25 Nm).
  3. Connect the ECT sensor harness connector.
  4. Fill the cooling system.
5.3L Engine To Remove:
  1. Drain the coolant below the level of the engine coolant temperature (ECT) sensor.
  2. Disconnect the ECT sensor electrical connector. ECT sensor 5.3L gm-04-53-4322.gif
  3. Remove the ECT sensor from the cylinder head.
To Install:
  1. Clean the threads in the sensor mounting hole.
  2. Apply sealer P/N 13246004 or equivalent to the threads of the sensor.
  3. Install the sensor and tighten 15 ft-lb (20 Nm).
  4. Connect the ECT sensor electrical connector.
  5. Fill the cooling system and check for leaks.
Sep 25, 2010 | 2006 Pontiac Grand Prix
Some odd electrical things are going on with my grandfathers Lincoln. the one I'm stuck on is the outside thermometer. Recently it has been in the 90's and even a week of 100+ degree's. The vehicle outside...
Its the ambient air temp sensor. This is usually located up in the front of the car behind the grill attached to the center post that the hood latch is mounted to. It is a 2 wire connector, unplug, replace, replug. Temp will take a few minutes to "calibrate" and all will be well.
Aug 07, 2009 | 1994 Lincoln Town Car
SkyScan 86709 Atomic Wall Clock Logo
42 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
