Question about Brine Lacrosse Brine 10x30 Backstop White
Brine 10x30 backstop setup instructions
I lost the instruction to set up the wall do you have them
Assembly instructions
This video might give you a hint?
https://www.youtube.com/watch?v=EAU0bX7uk7s
Jul 06, 2015 | Camping, Backpacking & Hiking
Vivitar 40 piece microscope set shrimp hatchery instructions
1. To hatch the eggs, first prepare a brine solution. Pour the entire contents of a vial containing sea salt into a quart of
tap water. Add the brine shrimp eggs into the
solution. Allow the solution to stand at room
temperature (70 - 80F or 21 - 26C) for 24
to 48 hours and the eggs will hatch into nauplius larvae (this is the first stage of development after leaving the eggs).
2. Place some of the larvae into one of the compartments of the shrimp hatchery .
3. Place some fresh brine solution in another
compartment. Add a small amount of yeast to
this new solution. Then, using the eyedropper, transfer some of the larvae into this compartment as well. The yeast will
serve as food and produce oxygen for the larvae as they develop into maturity. Without food and oxygen, the shrimp cannot develop
and will die. Mature brine shrimp are known
as Artemia Salina.
Note: Using an eyedropper with just the right
pressure to get a desired amount of liquid
onto a slide can be harder than it looks. Take
out a clean slide and practice squeezing a
drop of water onto the slide until you feel
comfortable that you can control the size of
the drop that you're squeezing out.
4. Observe the life cycle of the shrimp as they
grow: the dried eggs, the hatching eggs, the
developing larvae, and finally, the mature
shrimp.
5. The mature shrimp may be fed to fish in an
aquarium if you so wish. However, first
remove the shrimp from the brine solution
and place them into fresh water. An increase
in salt may harm the fish in the aquarium.
NOTE: Use the color filter especially when looking at clear or dim specimens.
Jan 20, 2013 | Vivitar 40 Piece Microscope Set
Lost instruction book what setting do you put it
I believe you need to scroll down to filters in one of the setup modes. You should find black and white there.
Aug 29, 2009 | Cameras
Shrimp Instructions?
Hi brine shrimp are sea monkeys just google see monkey hatching instructions they will be the same. my instructions do not have the information either but my set came with the brine shrimp. you just wont have pouch #1
http://www.discoverthis.com/sea-monkey-instructions.html
http://www.discoverthis.com/seamonkeys-hatching-temperature.html
Good luck we had 4 generations of sea monkeys. When they fie off you can let the water evaporate from your tank and Add new water and the cycle wiil start all over. we are in that process now 4th time...
Dec 31, 2008 | Vivitar 900x 28-piece Microscope Set
I need instructions for brine shrimp haching
I HAVE THE INSTRUCTIONS . IS THERE SOMEWAY TO EMAIL THEM TO YOU ??
Dec 21, 2008 | Vivitar 900x 28-piece Microscope Set
Shrimp Hatchery Instructions
according to the directions: condensed
prepare brine solution. pour all vile contents in to sea salt mixture,
fill 1quart of tap water
add brine shrimp into the 1 qt of water keep at 70- 80 degrees
should hatch in 24-48 hours
place into one of the compartments shrimp hatchery fig1 which is blue oval type container with dividers
place brine water with a small amount of yeast into a seperate compartment
use a dropper to place some of the larvea into this compartment
the larvea will feed on the yeast and provide oxygen
I have one of these and the light does not work it is brand new
is there a trick to it
email me if you can
IKNOWJESUS1@HOTMAIL.COM
Sep 01, 2008 | Science & Laboratory
Brine Lacrosse Brine 10x30 Backstop White Logo
515 people viewed this question
Top Brine Lacrosse Sport & Outdoor - Others Experts
Are you a Brine Lacrosse Sport and Outdoor - Other Expert? Answer questions, earn points and help others
