Panasonic SA-PM38DB Micro System Fan Noise
We have a whirring noise from the rear fan when switching system on, eventually quietens after about 30 seconds & doesn't reoccur. Have tried tightening screws that hold it in place, but no joy. The system is only 3 years old (out of warranty) so want to fix it, not replace it!! Any ideas?
djnick989
  • 1067 Answers
SOURCE: fan check issue
ya need to get fan fixed is safe mode cuse they genrate alot of heat have to have it in well vented area on a nice power strip like monster
Posted on Jan 09, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
uge44
  • 226 Answers
SOURCE: Noisy Fan
There are lots of reports of noisy fans. The closest one I can find is to fit a HT-Q70T. It's part no: AH31-00039B. It's a "Motor-Fan C151BK10A2430".
Posted on Nov 20, 2008
ravichetty
  • 158 Answers
SOURCE: "NO DISC" and no power to fan--Common Cause???
REPLACE THE LASER- THE FAN WORKS WITH VOLUME,AS YOU GO LOUDER THE FAN STARTS TO WORK
Posted on Aug 03, 2009
  • 336 Answers
SOURCE: F16 error occurs when trying to switch on DVD Home Cinema System
F16? I've seen F61. Usually an output IC problem, but it can be caused by a bad fan.
Remove the fan. Remove the sticker from the fan. Remove the small round piece of plastic (if it has one) from under the sticker. Put a couple of drops of oil or wd40 it it and spin the fan blades several times. Replace piece of plastic and sticker. Re-install the fan. Good Luck.
Posted on Feb 11, 2010
How to fix a fan on a panasonic sa-ht743
Pull the fan out, get the part number and manufacturer off the fan. Then go online to Allied Electronics and do a part search. If it does not pop up give them a call and they will find it for you. should cost you around 10 to 15 bucks.
Nov 14, 2013 | Panasonic SC-HT743 System
MY E-MACHINE MODEL NUMBER T-3985 MAKES ALOT OF NOISE WHEN RUNNING.
If it is a clicking noise, then that means your hard drive is probably starting to go. If it's a humming noise, then it's the system fan that keeps the computer cool. Try cleaning the fan and if that doesn't work, purchase a new one and replace. They are fairly cheap and easy to replace. If the fan stops working, it can cause the computer to heat up and may cause components such as the processor and hard drive to fail.
Mar 02, 2011 | E-Machines eMachines Desktop PC
Hello i get the F61 err on my Panasonic SA-DT100. i have cleaned the fan and it works but still i got the error
Maybe the fan doesn't rotate at the proper speed. Try to put some oil on the bearing sleeve or even replace the fan.
If it offers resistance it will show F61 and disconnect.
Nov 16, 2010 | Panasonic SC-DT100 System
My wii is making a whirring noise. Still reads
This is no doubt your system fan. it may be dusty and now having some trouble doing what it does. compressed air should clean this for you, unless you want to open it and manually clean the fan.
Hope this helps you.
Jan 04, 2010 | Nintendo Wii Console
Panasonic SC-HT995 locked
check the fan, if its dusty clean it then run the player. If it works, your in luck. If the fans are moving and f61 still shows up, the D-amp IC is shortened ( inside you will see IC 5000/IC5200 / IC 5300, these needs to be replaced) its the one by the big cooling fins (behind the rear fan)
Nov 11, 2009 | Panasonic SC-HT995W System
Whirring sound after long drives 2006 Chrysler Town & Country
It is your power steering pump. The solution is to replace the P/S fluid resevoir and fill or flush the system.
Mar 07, 2009 | 2006 Chrysler Town & Country
Loud whirring noise from home theater receiver
Sounds like a cooling fan is worn out. If the warranty has expired, remove the cover and there should be a cooling fan. Remove the fan. Try cleaning it out with a can of compressed air. If this does not work take the fan to best buy or circuit city and buy a replacement. I hopet his solves your problem!
Jan 09, 2009 | Samsung HT-TZ512T Theater System with...
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Big Screen gets loud, mad and turns off
without a model number, i can't be much help. if this is a newer dlp or similar tv, the fan is probably going out. some newer tv's have a fan that is part of the light assembly, some have a separate fan.. the loud whirring noise is usually caused by bad bearings or the blades of the fan may have become unbalanced, either way, the fan making the noise will need replacing. the color going is usually caused by the lcd or dlp overheating and/or the lamp overheating.
if the tv is out of warranty, remove the back panel, locate the fan making the noise, and search for a replacement. if you have a model number, i can check around and see if i can find the part number for you.
hope this helps,
trin
Nov 19, 2007 | Televison & Video
100 people viewed this question
 Grubhead
Grubhead
