Question about Acer Aspire Computers & Internet
No bootable divice please restart system
Its a blak screen it says no bootable device--please restart system, but i dont get nothing to work it just stays there?
  • 159 Answers
This screen appears when
hard drive has been removed, dislodged or stop working
to rule out the 1st two options
if your technical enough
turn power off remove charger and battery from laptop then try to reseat the hard drive
Posted on Apr 21, 2013
sayedmohu
  • 602 Answers
SOURCE: i got an acer aspire
Start the computer and keep tapping F2.
No u will be in the setup utility.
Press F9 for loading default settings and press enter.
Press F10 for saving settings and press enter.
Now your computer will restart.
If u are getting the same error message, u should replace your hard drive.
If not, try doing a complete system recovery.
Follow the steps to do system recovery.
Power on the netbook and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Also note that u will lose all your datas.
Posted on Dec 26, 2010
tarnalcock
  • 41 Answers
SOURCE: When I start up the
If your system is still under warranty, take it back to the supplier if not then your nearest pc repair centre. Sounds to me like your HDD is going. This is rather unusual considering most of them are SSDs but some do have 1.8" ZIF drives in.
Posted on Nov 16, 2010
tgvern
  • 281 Answers
SOURCE: my daughter has a acer
It sure sounds like a problem with the hard drive. Acers usually don't include diagnostic tools to check it out, but that is what I would do next. If you don't know how to proceed, use a hard drive diagnostic like DFT to diagnose the hard drive.
visit http://www.hitachigst.com/support/downloads/
to get the info and download the DFT program. This will work on non-Hitachi drives as well, so don't worry about what type of drive is in your Acer.
If the drive is bad, it is a fairly simple matter of installing a new hard drive and reinstalling windows onto it. It's hard to say if the data on that drive is recoverable or not.
Posted on Aug 03, 2011
  • 1288 Answers
SOURCE: when i turn my acer
Hi
It looks as though the laptop is not recognising the hard drive, there is no hard drive fitted or there is a hard drive but the OS boot record has been wiped ( I know this sounds obvious but some people buy these 2nd hand only to find the hard drive was removed)
You need to check the hard drive is present by booting to the bios screen it should "see" the hard drive attached. If it is present, then you have a problem with the OS or a damaged hard drive. I think its DEL or F2 or F10 to access the bios, not certain.
At this point, you need to attempt to reinstall the OS, as this does not have an optical drive, you will need to obtain a USB Optical drive, go into the bios and see that it is recognised as a boot device. Do not worry about setting the boot order, the Bios will locate the rom as a boot device.
Attempt a start up repair, ie: wait until the installer looks for a previous installation of windows (if one exists) then allow it to install a repair installation. If it does NOT find this, you will need to doa full install. If at this point you have files you need recovering, a strip down of the netbook and removal of the hard drive will be necessary. You simply then get someone with a computer to jumper your hard drive as a slave and recover the files you need, as a full install requires the hard drive to be fully wiped.
Replace the hard drive after you have done this and proceed with the full reinstall
You can use a USB boot device, but to do this you will need to have access to another computer to make the boot installer:
here
Posted on Aug 02, 2011
maxcarson
  • 7627 Answers
SOURCE: acer aspire one i am getting no bootable device--please restart system...HOW?
At the white ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery
Posted on Nov 16, 2012
I have a toshiba satellite pro c850 -1he and I reset my computer and it crashed and now it gives me a error message saying " no bootable device -- please restart system" Ive tried that it dont work I
It is not recognizing your hard drive. Put your Windows installation DVD in the optical drive and try restarting again. It MAY be able to help you but the data on your hard drive may be permanently damaged. You may have to reinstall Windows and all of your applications.
Feb 16, 2015 | Toshiba Computers & Internet
So I lost my temper and slammed my Gateway
Check the hdd connector for damage.
Sep 26, 2014 | Computers & Internet
No bootable device -- please restart system
THIS IS A BIOS CONFIGURATION ISSUE. WHEN YOU RESTART THE 'PUTER, HIT F2 OR F12 TO ENTER SYSTEM CONFIGURATION. THEN FIND THE MENU ITEM FOR HARD DRIVES AND MAKE SURE THEY ARE RECOGNIZED / PRESENT ON THIS BIOS CONFIG. SCREEN. SET THE HD TO PRIMARY. SAVE/QUIT AND RESTART. THIS IS A STARTING POINT FOR FURTHER DIAGNOSIS. YOU MAY HAVE TO 'DBAN' THE DRIVE.
Mar 28, 2014 | Toshiba Satellite S75-A7270 17.3" LED...
Getting message on my laptop saying no bootable divice
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 24, 2012 | Computers & Internet
Type your question here...
My Inspiron duo comes up no bootable divice please restart system what do I do
Aug 30, 2011 | Dell Inspiron 2200 Notebook
Acer notebook won't boot. help
if u can go onlne from an other pc, i'll give u a link to the mot famous maintanance bootable cd,
Burn it, start ur acer while the cd is in the drive.
http://www.hirensbootcd.net/download.html
Jun 14, 2010 | Acer Aspire One PC Notebook
How change bootable device?
You can do this one of two ways
1. with the DVD in the laptop hold down the option button as the computer is starting this will bring you to a menu where you can your boot device.
or
2.With the laptop powered off again with the DVD in
Press the powerbutton and hold down the "c" key this will boot directly to the DVD
***It sounds like you have your boot device in the system preferences set to your XP disk. You can fix this once you boot the mac partion by selecting System Preferences then selecting Startup Disk and choosing the disk you want to boot the drive with.
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP (anything less hurts our averages)
Thank you and good luck!
Feb 07, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Ok..So I've had my tx2500 for a little over a year now (go figure, the warranty's out). After I booted up today, I went online and after a few minutes, the screen went pixel'y' and then went blank. The...
there is something wrong with the video driver or the monitor...If the screen shows something like the devices when it boots up...and only goes blak when it logs to windows...I mean if you see all on the screen until you get to the windows logo..this is a operating system error ..a driver seting or crash...so ...just reinstall it ..or repair the operation system ..cause if it is a setting on video driver or a error ..you can not fix it if you do not see anything ..
if the system boots but you never see a thing on the monitor...not even the writen devices when it first starts..or the bios..this means that the screen or the ribbon of the monitor has a damage on..try to change its position...or so ..but in this case you will need a ribbon for sure ...
Jan 31, 2010 | HP Pavilion tx2500z Notebook
How to find audio divice driver on windows xp.no audio divice on my com
The sound device is software usually located on the mother bord install disk. else see what kind of sound the board takes and got to their , for instance realtec, sound company, web site and download the audio device and the driver , if you don't have the MB CD.
Nov 24, 2008 | M-Audio Fast Track Pro External Sound...
Computers & Internet Logo
623 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
