Question about Whirlpool GU2400XTP Built-in Dishwasher
The start light just blinks and the dishwasher wont start?
The start light just blinks constantly and the dishwasher will not start...Is there a reset button somewhere or what might the problem be?
  • jamesmonagha Mar 14, 2009
    I figures out it was the latch..just had to bend it a little and it worked fine..thanks for the help...
Just found a web site that says crack door open, press normal, hot dry, normal, hot dry, then cancel to reset the controls.
Posted on Mar 14, 2009
Cancel light blinks maytag dishwasher
Check door switch. Also, the control pad may be shorted from water getting in between the plastic and corroding the connections to the buttons. DW
Apr 11, 2014 | Maytag Dishwashers
Dishwasher clean light blinks constantly, can't get washer to start up and wash. Buttons will light up but it wont start.
Hello, Thank You for using FixYa. I will be helping you today.Try pressing heated dry,Normal,Heated dry,Normal and all lights should come on if they do wait like 5 seconds and hit cancel and see if the unit will start. If this happens again it may be a heating issue.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | KitchenAid Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The Normal Wash light blinks constantly. I cannot
Try unplugging it for 15 then plug it back in. It should reset itself. Sometimes water temp sensors or water level sensors can get dirty or corroded and give you this error.
Jun 14, 2010 | Kenmore 24 in. 17012 Built-in Dishwasher
Blinking clean light
This blinking indicates a failure to properly heat the water, the link below will have instructions on how to reset the control so you can use the dishwasher and it will provide areas to look as to why it failed. Let me know if it was helpful.
Blinking Clean light
May 23, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
421 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
