Question about Reliance Water Heater #9003531 NAT Gas Pilot Assembly
What is the differance in a 9003542 and 9003531
I ordered a thermocouple for my reliance 606 and when it came in it said to make sure the TCO was correct also I noticed that the new one says 190 degree and my says 182 degree
  • Reliance Master
  • 5,245 Answers
For technical information Contact Reliance parent company AO Smith.
http://www.aosmith.com/Utility/Forms.aspx?ekfrm=973
Post question on pro water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Test thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Posted on Apr 22, 2013
3 Suggested Answers
  • 832 Answers
SOURCE: Our 606 reliance electric hot water heater has the
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Posted on Nov 27, 2009
  • 3640 Answers
SOURCE: how to change bad thermocouple on reliance gas hot
it is important to turn off
the gas supply to the water heater at the manual gas shut-off
valve. This valve is typically located beside the water heater.
Note the position of the shut-off valve in the open/on position
then proceed to turn it off.
2. On the lower front of the water heater locate the combination
gas control valve/thermostat. Depress and hold
the lock tab located under the gas control knob on the right.
Rotate the gas control knob on the combination gas control
valve/thermostat clockwise until "OFF" aligns with the mark on
the front of the gas valve. Once the gas supply has been shutoff,
remove outer door. 3. Using a 1/4" nut driver or socket loosen the two screws securing
the manifold door assembly until they are free. Do not
totally remove the screws and plastic retainer washers from
the manifold door. The screws and retainer washers will be
needed to reattach the manifold door. 4. In this step, the thermocouple, manifold tube, pilot tube and
igniter wire will be disconnected from the combination gas
control valve/thermostat. Using a 7/16" wrench
disconnect the thermocouple (left-hand thread) and pilot tube
(right-hand thread). Using a 3/4" wrench disconnect the manifold
tube (right-hand thread). Carefully pull the igniter wire from
the igniter button.
5. Grasp the manifold tube and push down slightly to free the
manifold tube, pilot tube, and thermocouple from the combination
gas control valve/thermostat. when installation is complete and gas is back on, You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Posted on Nov 27, 2010
How to change thermocouple on model 640YORT
I believe that is a Reliance 606, ehow has instructions on how to change the thermocouple.
http://www.ehow.com/how_6579030_change-reliance-606-thermocouple.html
Aug 24, 2014 | Water Heaters
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add comment and say what you tried so far.
Include age of water heater.
Jan 05, 2013 | Reliance & LP Gas Water Heater Control
Need gas control unit& burner for water heater 40 gallon
Reliance is AO Smith.
Each gas control has identifying information on side of gas control valve. Make sure you order for NG natural gas or LP propane gas, since these are two different gas control valves.
Google search the gas control number and results will show.
Copy following links for more help:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 03, 2012 | Reliance Water Heaters
How to remove burner assy. from relieance 606 yort water heater?
Copy following link for step by step illustration removing burner assembly (and replacing thermocouple or cleaning combustion parts).
Reliance is made by Rheem and probably has tamper proof screws.
Aug 04, 2012 | Water Heaters
Model 640HORT Reliance 606 40 gal LPgas came to cabin, water cold, lit; ran for 4 hours, flame went out, burner won't come on.
It does sound like a weak pilot thermocouple. Change the thermocouple first. Make sure you have an adequate supply of propane serving the water heater. If it still works for a while then completely shuts down, you will need to replace the control valve. Call Reliance and see if the unit is still under warranty, you may be able to get free parts.
Sep 11, 2010 | Reliance & LP Gas Water Heater Control
Model #606 640nort Reliance 30gal gas water heater
this is either the thermocouple lead or the uni control i would replace the thermocouple leed first, these parts can't be repaired they have to be replaced
Jul 13, 2010 | Reliance & 30 Gal LP Gas Water Heater
My reliance 606 hot water tank pilot wont stay on soon i release it it goes out and no hot water what do i need to do to solve the prolem myself?
You need to replace the thermocouple. It unscrews from the thermostat on one end, and the other one hooks in a bracket. After replacment make sure the thermocouple bulb is in the pilot flame.
Apr 08, 2010 | Reliance & 40 Gal Electric Mobile Home...
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
Reliance Water Heater #9003531 NAT Gas Pilot Assembly Logo
283 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
