Question about Compaq Computers & Internet
BLUE SCREEN Here's the issue, I have had my computer for a while/years. First off 6 months ago the disk drive stopped working and my systems have been running very slow. 2 days ago i installed the Service Pack 2 and now my computer wont even start up. I got on the chat line and had a chat with the rep, she said my Presario V2000 come with a F11 recovery option but it doesn't. It has the option to use ESC to get in to the boot option, F10 for the same and F12 for internet boot. I have tried every boot method my computer will do and even tried safe and nothing. A few side notes, my hard drive is one from another HP comp and it is about 3-4 years old. I was also going to buy a 4 gig up grade that the tech said would work, but the rep i chatted with said i could only upgrade to 2 gigs.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 51 Answers
Is what happen to your laptop is lower specs i thought..so you need to re-install the windows comptaible to your laptop and meet the specs...but before you do that you need to back up 1st your important files..
Posted on Mar 12, 2009
Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Aug 21, 2012 | Lenovo IdeaPad U550 Notebook
HP Pavillion m7750n has already had the hard drive replaced almost two years ago. The computer will be four in January. It stopped working about five months ago and I finally decided I had enough time to...
Either the disk is faulty or the the boot block is corrupted. If you have the operating system CD, you can try to reload it. Doing so will wipe out anything you have on the drive. If it reloads, you will be back in business. It the disk is faulty, the OS will not load.
You may want to take this computer into the Big Box store and have it evaluated before youtry to do this repair.
Thanks for your interest in FixYa.com
Nov 23, 2010 | HP Pavilion m7750n PC Desktop
WD800U017 passport problem
The drive in the case is broken. You will have to take the drive to data recovery centre to recover your data.
Aug 03, 2009 | Western Digital Passport WDXML800UE...
Acer 5100 Vista Boot up issue
sounds like you need to reinstall the operating system. if you don't have the disk you can call acer and they will send you the disk. they might charge you for the disk usually between $15 and $30.
Mar 01, 2009 | Acer Aspire 5100 Notebook
Blue Screen (NO EBRAKE Message) Ebrake code entered and worked
hook your green/white camera override wire to your parking wire that should solve your problem
Feb 20, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
HD stops working after 45 seconds
It seems you figure out the issue. If its under warranty then have it the "power" replaced.
Jan 24, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Blue screen with error message on startup
Most likely problem is a physical problem with the hard drive, but could be plenty of other things. Best bet is to back up your information (if possible) and do a fresh windows install, if you continue to get the message after a clean windows install, your hard drive is not stable, and has a problem.
Dec 30, 2008 | Dell Inspiron 6000 Notebook
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
LaCie 250GB Ethernet Disk Mini (300938U) Won't Power Up
Hi
External drives of this type are usually internal drives with case power supply etc. You should be able to open the box remove hard drive connect as a 2nd hard drive to PC either sata or ide depending on drive PC should recognise drive at boot up then you can access files and back up to CD, DVD, hard disk. If you are not comfortable doing this usually local PC repair shop will do for small charge. Assuming of course that the hard drive itself is not dead, just the power supply for the external case.
Hope this helps
May 07, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
