Question about Proform Exercise & Fitness
Icon p/n m175310
Treadmill proform motor
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
  • 82 Answers
SOURCE: Proform 590 HR Treadmill. Belt won't run
Hi, i fixed one just the other day, the control unit fails.
broddersbaldrick on a big auction site fixes them :)
Hope this helps
Posted on Apr 22, 2010
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Proform 515 TX; no power to motor; display shows time elapsing and distance traveled. What is the likelihood that the controller is bad?
1) test the terminal motor with VOM, if there are Voltage the motor is faulty.
2) test the output voltage coming from control board, if there are Not voltage for to input voltage motor, the board is faulty.replace
God bless you
Oct 13, 2013 | Icon ProForm 515 TX Treadmill
ProForm cross trainer 565. Press start it races for a few seconds then stops. The console keeps going as if everything is still working.
One of the motor controller transistors is shorted.
Phone ICON customer service and order a new controller. It is relatively easy to install. The phone number is on the model number tag..
Feb 05, 2013 | Proform 565 Crosstrainer Treadmill Console
What is the best treadmill brand?
1) Weslo Of all the Icon brands, Weslo treadmills are the least expensive, and in fact are typically the lowest priced of any treadmill regardless of manufacturer. They are entry-level machines intended for use by beginners and walkers that do not engage in a more demanding workout. They lack the power of more expensive brands and are built with smaller running areas. And warranties are typically no longer than 90 days.
In the Weslo line, the Weslo 400 CS treadmill sells for under $400. It is consistently picked as one of the top budget treadmill models.
2)Image
Image is another brand of treadmill produced by Icon Fitness. This line is slightly more expensive than Weslo, but is still considered a budget machine, typically selling for under $1000. Many experts feel that Image treadmills offer the best value for the average person. The only drawback is the warranty, which is only 90 days on many Image models.
The Image 1200 treadmill has a 2.0 hp continuous duty motor that provides a maximum speed of 10 mph. The platform can adjust to inclines from 0-10%. It is a great choice for those runners on a bit of a budget and for those who want to spend $1000 or less. The Image 10.6QL was ranked among the top five treadmills by U.S. Consumer Reports. It has six programmable workouts and also allows you to determine your speed and incline based on a heart rate monitor. It is IFIT compatible, which means you can connect to the Internet to access online workouts. It costs around $1400 and is folding for convenient storage.
3) Proform
Proform treadmills by Icon provide shoppers with perhaps the most comprehensive options in exercise equipment. Budget models start at $400 and the overwhelming selection continues up the spectrum to several mid priced models that fall in the $1000 to $2000 range. The Proform 795SL treadmill sells for under $1000 and is often a top pick among consumers and fitness experts. The LX 660 sells for under $600 and has plenty of features for a budget treadmill. Like many of the budget treadmills, Proforms often have a less than stellar warranty, typically 90 days.
4) NordicTrack
There are literally dozens of different NordicTrack treadmill models produced by Icon. They range in price from around $800 for a NordicTrack C1800 to $2000 for a 7500R model. Many fitness experts feel that consumers spend a bit more for the name brand when they purchase a Nordictrack treadmill. The machines often look very nice but may not always offer the best buy as some people have experienced problems with reliability. All models typically come with a heart rate monitor, but some of the less expensive models offer a 1.5 hp motor and a smaller platform, often around 50".
5) Reebok
Reebok treadmills also depend on name recognition to help attract buyers. Models often look nice and have plenty of features but have been known to be less durable than other brands. It is important to note that Reebok home treadmills are not made by the same company as the commercial models found in fitness clubs.
Please vote.
Thanks
George
Jan 12, 2011 | Proform 695 LT Treadmill
I have a Proform 590T treadmill that is 3 months old - about 60 - 75 miles on it and it has become noisy. Not a clunking just a loud hum. It is the same noise regardless if you are walking on it or just...
It might be motor bearings or a roller. Remove the drive belt and run the machine.
Icon has a good warranty program. I am a service tech for the company working in Canada. If it is only 3 months old, call ICON and arrange a service call from a qualified tech.
1-888-533-1333.
Dec 14, 2010 | Proform 590T Treadmill
I dont have a promblem but i was given a proform 730 and i dont have a manuel to program
This treadmill is made by Icon Health and Fitness. You can download a manual by going to www.iconservice.com and using your model number.
May 20, 2010 | Proform Sport 1000 Folding Treadmill...
The proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Apr 30, 2010 | Proform 980 CS Treadmill
Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Jun 06, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
77 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
