Question about Respironics REMstar Pro2 w/ C-Flex CPAP
Cpap Service Manual
E-24
Showing Error Code E1
If you wish to get some details; check the site linked here. Pull up older posts.
http://homenol.blogspot.com/
Aug 31, 2016 | Fisher Paykel Fisher & Paykel SleepStyle...
I need top cover for my humidifier part number 324866-301 does anyone know where I can find one?
Shop for Humidifiers' top cover on Google
CPAP.com - H4i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../resmed-h4i-heated-humidifier-top-cover-seal.html
People Who Bought H4i™ Heated Humidifier Top Cover Lid and Seal Also Bought. ... This is the plastic cover used with the Resmed Humidiare H4i Heated Humidifier. ... People Who Viewed H4i™ Heated Humidifier Top Cover Lid and Seal Also Viewed.
HumidAire 3i Heated Humidifier Top Cover Lid and Seal
www.cpap.com/.../H3i-Heated-Humidifier-Top-Cover-and-Seal.html
This is the plastic cover used with the Resmed H3i Heated Humidifier. It also includes the plastic gasket below the tube connector.
Sep 29, 2015 | Humidifiers
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
How do i change pressure in CPAP
http://www.wikihow.com/Adjust-Pressure-on-a-Respironics-CPAP-Machine
I swear it's like no one's heard of google...
Nov 14, 2012 | Respironics SleepEasy Sleep Therapy System...
No water flow into the filter
Hello. the first thing you need to determine is if the solenoid is getting 24 volts when the furnace turns on, you should be getting 24 volts at the solenoid valve. If not you need to start at the transformer and see if you are getting 24 volts there, if not then most likely the transformer is bad and must be replaced, if you are getting 24 volts at the transformer then check the wiring and make sure it;s tight. also check the humidistat and sail switch/ current sensing relay to make sure they are working properly. If you are getting 24 volts at the solenoid valve and is not allowing water thru than it must be replaced.
Feb 22, 2011 | General Filters 1099-LH Humidifier
There is no water coming out, i have an aprilaire 600 model with a manual controler
The first thing you want to check is that the saddle valve is open and that water is getting to the solenoid. If you are getting water to the solenoid but it's not going through then most likely you are not getting power to the solenoid. When there is a call for heat you should be getting 24 volts to the solenoid and it will open allowing water into the humidifier, if you are not getting 24 volts then check the transformer make sure it is giving you 24 volts.
Dec 18, 2010 | Aprilaire 600 Humidifier
Humidifier control: red light is on. getting 24
the red light is lit because either you didnt install the manual mode resistor or your not using a out door thermostat but you have to hook somthing to the two terminals just to the right of the HH terminals
Dec 23, 2009 | Aprilaire 600 Humidifier
I have a 550 ...I have 3 questions. 1. Can I
1.yes you can service it yourself the 550 takes a number 10 pad I recomend the oem pads for there strength and durability. You need to clean the bottom tray of any lime scale I use a stainless scrunchie. the top tray has a sandy grit surface that should stay there, just clean away the lime scale. Then shut water valve off to the unit remove the incoming line from the solenoid valve and use a dental pick to remove the strainer,clean this out thouroughly of any debri and return it to its home and reconnect the line. Next go to the other side of the solenoid valve and remove the compression nut there blow on the tube to make sure the orifice is clear if not use a orifice drill the same size and clean it out. Return the tube and tighten the compression nut. If all nuts are tight turn water back on (if you have a needle valve which most people use even though there against code, you may need to tighten the packing nut) and check for leaks. Set humidistat till it clicks for testing(this is a manual type with numbers 15% to 45%) then turn on furnace. Depending upon which furnace you have some are tied into the circuit board others have a current sensing relay attached to a 24 volt transformer. You should here the solenoid thump when the furnace kicks in or blower starts. If not you need to check for voltage at the solenoid the 2 wires there will read 24 volts. If not you may have a faulty current sensing relay or other problems. If all work set humidistat to 35% and watch your relative humidity in the house. You may have to adjust as it gets cloder to a lower humidity
Have at it my fingers are cracked enough from cleaning humidifiers
Tinner
Sunsetmech
Dec 14, 2009 | Aprilaire 550 Humidifier
AprilAire 760 not running after installing new circuit board
I called the service company that put in my new furnace (FAmily Heating and Cooling in Detroit, very highly recommend these people)
Anyway they sent out a second service tech who determined that I would be better off having the humidifier wired to go on whenever the furnace fan was running instead of using the humidifier signal from the circuit board on the furnace. After he changed the wiring the unit runs fine. It is pretty likely that the circuit board was bad also.
Nov 27, 2008 | Aprilaire 700 Humidifier
Respironics REMstar Pro2 w/ C-Flex CPAP Logo
339 people viewed this question
Top Respironics Humidifiers Experts
Lawrence Oravetz
Tom Chichester
Are you a Respironics Humidifier Expert? Answer questions, earn points and help others
