Question about Garden
Carburetor troubleshooting ENGINE STOPS WHEN THROTEL IS OPENED
Carb may need adjusting
Posted on Apr 21, 2013
How to adjust valves on pro 300 x19.5 hp
Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
store.chainsawr.com/.../1126042-adjustment-and-tuning-of-a-chainsaw-c...
Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain sawsand ... The throttle valve (butterfly) simply cuts off the supply of combustible air/fuel and the engine stops. .... (7) Go back to step (5) and reset the idle speed.Missing: 300 ‎x19 ‎hp
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Fuel valve shut off; Fuel solenoid inoperative. ... Pull starter rope to setengine on compression. ... i cant get motor to idle its a b&s 300 series 4.50 model 9t602 type 5019 serial 11082954 aug ... i have a 17 hp kohler command that backfires when i try to start it, it has a new coil and i ... July 5, 2015 at 1:46 pm.
TWO-STROKE REED VALVE EXPLAINED - YouTube
? 7:08
https://www.youtube.com/watch?v=S8-bR7DMpbg
Feb 27, 2008 - Uploaded by DIOSpeedDemon
The reed valve is very important for a high perfomance DIO engine. ... The valve material is of great concern when building these engines. ... DIOSpeedDemon 5 months ago ..... 300 HP 2 STROKE - Duration: 1:05. jangho9 218,194 views ... Two-Stroke Scooter / ATV Carburetor Settings And Adjustments ...Missing: chainsaws ‎pro ‎x19
Jan 25, 2016 | Garden
Troy bilt troubleshooting
Your carburetor is probably gummed up and dirty, or float in carb may be bad. The float shuts the needle and seat off and stops flow of gas into the carburetor. If it's gummed up or float is bad or dirt in the bowl of carburetor etc. it will not shut fuel off and gas will just keep flowing and get into engine. Will run out muffler and also possibly into crankcase(engine oil). Check oil for over full condition and if it has strong gas smell. Good idea to change it anyway.
Aug 15, 2014 | Garden
Falls on its face when you crank on the throtel more than half
At about half throttle the fuel flow starts being controlled by the needle and main jet. for some reason, your carburetor is not providing enough fuel to the engine during this phase of operation. Check for a tear or hole in the diaphragm on the needle slide or for a sticking slide. be sure the float level is correct and nothing is obstructing fuel flow through the main jet. also check the fuel filter and lines for obstructions.
Apr 08, 2014 | 2006 kawasaki Vulcan 800 Drifter
Masport 635 starts, revs up once, and dies. Will start again a few pulls later. Carb diaphragm has been replaced with no change. Could it be ignition? Thanks.
follow this steps and fix it. God bless you
Carburetor
If the lawn mower engine stops after a few seconds, the carburetor might be clogged or have bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This sticky fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Carburetor Kit
If the engine stops after a few seconds it may not be getting enough fuel. The engine needs air, fuel and spark to maintain operation. The carburetor has two inputs, fuel from the gas tank and air through the air filter. The carburetor is designed to mix the air and fuel in a consistent ratio so that the engine can run continuously. If the carburetor is not getting enough air or fuel, or if the fuel is blocked inside the carburetor the engine stops after a few seconds. Rebuild the carburetor with this carburetor kit.
Gas Cap
If the lawn mower engine stops after a few seconds and then stops running, the gas cap might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it should be replaced.
Gas Cap with Gauge
If the lawn mower engine stops after a few seconds and then stops running, the gas cap with gauge might be defective. All gas caps have a small vent to allow air back into the tank when the engine is running - otherwise as gas is drawn from the tank it would create a vacuum. The vent can be difficult to see and there are many different types of vent. If loosening the gas cap a little allows the engine to stay running, replace the gas cap. It's sometimes possible to clean the vent, but on most newer engines the vent cannot be cleaned, it has to be replaced.
Old or Bad Gasoline
If the lawn mower stops after a few seconds, the carburetor might be clogged or have old or bad fuel in the float bowl. If old fuel was left in the lawn mower for a long time some of the volatile ingredients may have evaporated, leaving a thicker, stickier product that is more like varnish or shellac. This old or bad fuel can clog up the small jets and ports in the carburetor and it can be difficult to burn allowing the engine to only run for a few seconds. The only solution is to drain the old or bad fuel from the float bowl and thoroughly clean the carburetor with carburetor cleaner. If that isn't effective, replace the entire carburetor.
Spark Plug
If the lawn mower engine stops after a few seconds the spark plug might be defective. All small engines have an ignition coil. The coil is the device that provides spark for the spark plug(s). If the coil is bad there won't be spark to the plug(s). The coil is essentially a small, induction generator. It is mounted next to the flywheel. The flywheel has one or more strong, embedded magnets. As the flywheel spins, the magnet(s) zip past the induction coil, this action of a magnet passing past a coil induces a voltage. Depending on the design of the coil and the strength of the magnets, a stronger or weaker spark can be created and delivered to the spark plug(s). Each time the flywheel spins around a spark is generated. The best way to test a spark plug is to use a spark plug tester. The spark plug should have a strong, visible spark between the electrodes when the engine is cranking. If it doesn't, replace it.
Nov 13, 2013 | Garden
WHAT IS MASSIVE AIR FLOW SENSOR
mass air flow sensor measeres the air intake for the engine not sure exactliy where its located on a toyota corolla but it is usualy located between the air filter box and the throtel body or some times its mounted on the throtel body
Jun 09, 2012 | 1999 Toyota Corolla
My husky 359 will start and run okay but stops after 5 - 10 mins of cutting and will not start again unless you use the choke, sometimes will not start again at all. I have replaced the fuel, spark plug...
Your description seems to imply improper fuel tank venting. Remove the fuel cap, then replace and try restart. If it now runs for another similar period, troubleshoot the vent. If no improvement, then check the fuel filter, fuel lines, and carburetor fasteners for tightness including the mounting fasteners to the cylinder. Does the primer bulb appear to be able to pull new fuel in when this problem occurs? Does the engine seem to be overheating? You may be having problems with the internals of the carburetor--it could be necessary to dismantle, clean and reassemble. Check especially the diaphragm in the lower section and the fuel metering valve that it controls. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting which applies to nearly every brand of carburetor used. Hope this helps!
Jun 10, 2010 | Husqvarna Chain Saw 20" Bar
Homelite starts with strarter fluid and then stops
Does the pumper bulb fill with fuel when pumped? I had a similar problem with a Homelite--which turned out to be the location of the carburetor lower-chamber gasket. The diaphragm needs to go to the carburetor body (pin inward), then the gasket and cover plate. Go to:
www.drystacked.com for a 12 page PDF document on Walbro carburetor theory, troubleshooting, and repair. Hope this helps!
Mar 29, 2010 | Homelite ZR10926 16" Chain Saw
How do i shut down the nitro engine on my kyosho airstreak r/c boat when i'm done driving it?
the engine should shut down when you close the throtel fully if not it needs ajustment so that it dose on your control you should have a trim tab if the trim is on the engine keeps running if you push the trim right off the engin stops
Mar 21, 2010 | Toys
I need a diagram showing how the throtel cable attaches to the carb on a Craftsman 17.5 hp, 42 in.,riding mower (NEW 2008)
The throttle cable doesn't attach to the carburetor. The 'z' bend in the end of the cable sticks in the white plastic slide at the bottom of the control plate on the left rear side of the engine and the cable is held in place by a clamp behind it.
Jun 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Truck just stops b- 2005 Ford F150 80,000 miles
it is probably the driver fuel pump modual (DFPM) it is located above the spare tire. they usually corrode away and shut dow the fuel pump intermittently. u may also have to replace the connector to due to corrosion
Dec 28, 2008 | 2005 Ford F-150
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
