Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Kenmore Model 790 gas range,oven not working.
Set control to preheat and temperature the broiler comes on instead of the oven, tried setting the control on bake,oven still dosen't come on.
  • Anonymous Mar 23, 2009
    Had a roast in the oven, oven switched from bake to broil and now does not work. Keeps showing a F-10 error message.
SOURCE: Roper stove/oven range
need a solution for this problem
Posted on Sep 04, 2007
  • 639 Answers
SOURCE: problem with oven preheating
Hi, I'm Neil
It is a fire hazard! Be Careful!
It's a gas regulator or thermostat
This time you will have to call the the manufacturer for service!
If it's under a year old ,your under warranty and it will not cost you anything!
Please give me a solution rating here!
Thank You
Posted on Aug 24, 2008
  • 96 Answers
SOURCE: Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Posted on Dec 19, 2008
SOURCE: Kenmore electric range 790. Both the broil and
I have the same problem... I checked both elements and they are fine. I was wondering if it was the ERC. Have you fixed yours yet? Please let me know.
Posted on Dec 06, 2009
  • 1430 Answers
SOURCE: Oven lights ,but doesn't heat to preset temperature
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Posted on Jun 17, 2010
Testimonial: "Exact problem and solution, Thanks"
My Kenmore Gas Range 790 makes a puffing sound every time the oven cycles on. Sometimes it is quite loud. In addition when I set the temperature the preheated beep sounds well before the temperature
It sounds like your oven igniiter is the problem. the part that glows in the oven. they get old after a few years and you can get a miner explosion when the burner lights. Replacing the igniter should fix this.
Nov 06, 2014 | Kitchen Ranges
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed '
Aug 19, 2014 | Kitchen Ranges
Kenmore 790 oven won't maintain temperature
anyone know where to buy the battery for hand phone model mini i9500 ? manufacturer is
Nov 12, 2013 | Kenmore Kitchen Ranges
Oven won't heat up
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 04, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Oven themostat not set correctly
Your thermomitor may be going or the oven sensor could be the problem. Buy a BRAND NEW thermomitor and put it in the middle of the middle rack and set to 350. After the preheat is done, wait another 10 min and read thermomitor with flashlight through door glass. This will be the MOST accurate way. to tell
Mar 26, 2009 | Kenmore Kitchen Ranges
Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
311 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
