Question about Canon PIXMA iP4000 InkJet Photo Printer
Problem with Canon Pixma iP5000
Hi, H E L P !!! When I swich on the printer it sounds as a machine gun and the Power button flashing orange/geen. Sometime I get a message like a head is not found or something like that. Perhaps it is something about my head.. Thank you in advance, Alex
  • Anonymous Apr 19, 2008
    how do you replace the print head? sounds like a machine gun. thanks.
    Genius:
  • 2,985 Answers
Try getting the head to the replace cartridge position[chech your hand book] Then reseat the cartridge. You could also look in at www.fixyourownprinter.com
Posted on Aug 05, 2007
SOURCE:
Canon Color Bubble Jet Printer i550 wiil not print - (greenlight then orange light blinks 8x - then green light) When attempting to print receive "Printer not responding" - "Paper thickness lever...
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Office Equipment & Supplies
Hi we dropped our printer it works but comes on and says ink is not in properly. i have pulled out and tried. geen and orange light comes on. same message again
Canon IP 2000 / reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 01, 2010 | Canon PIXMA iP2000 InkJet Printer
One page jammed after switching off when 1 page printed. Orange light on
Hi ,
First off all u switched off the printer and on switch off mode press the green button and on pressing the button switch on the printer hold that button for 5 seconds and then release the button whenever u realese the button the printer start migrating . After migrating if the printer have same problem then u reinstall the printer driver and again reinstall the driver, after reinstalling the driver the printer will working fine .
May 26, 2009 | HP LaserJet 1010 Printer
Flashing 3 times orange then green?
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
Mar 31, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please remember to rate all Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
In March 2008, I bought a CANON printer "PIXMA MP210" series. But, only last week I was abled to errected and connected the printer to my Fujitsu Life Book # A6110 (lap top). When switching on the...
is there any error message appear at your laptop..? have you check the ink cartridge inside, and also the mechanical parts inside if there was a paper jam..
Jun 27, 2008 | Office Equipment & Supplies
Canon pixmaip3000 states printer offline & does not print, flishing power lights green & orange
I have canon PIXMA ip3000. After power cut at night printer doen not print. I re installed the drivers but no result. When try to print message appears printer is offline. POwer button is flashing shorthly green after orange lights. Error code 5100.
Please advice what can I do urgently.
Mar 10, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma ip1500 - Orange Flashing light
may be "waste pad full" error
try:
4 step to Reset waste ink tank counter CANON PIXMA iP 1500
Feb 05, 2008 | Computers & Internet
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
213 people viewed this question
Clive
Clive
old marine
old marine
Ekse
