Question about Engel Refrigerators
Hi for an old 39lt engel fridge...just randomly stops working if used in the car but doesn't miss a beat in the house, not sure if the it gets unsettled in the car. The green light stays on and co
  • 87 Answers
SOURCE: GSH22JSRE SS not cooling
I would strongly advise seeking a competent fridge guy. If it is the compressor (which sounds like a distinct possibility) they should be able to identify it very quickly. They would then be able to give you a cost on replacement. Alternatively you could try throwing it back at where you got it from and see if there is an extended parts only warranty. Some manufacturers now have three or even five years warranty on major components (ie compressors). Although there is no guarantee of this, its always worth a try, you might get someone sympathetic to your plight, due to the young age of the cabinet. Hope this is of some if not limited use.
Posted on Sep 11, 2007
  • 27 Answers
SOURCE: Kenmore Fridge 4 yrs old side by side model not cooling
Hi. Your refrigerator is under 5 years and the compressor is still under full warranty. Call Sears and get it fixed parts and labor included. There should be no charge to you whatsoever. Make sure they understand that on the phone when you set up the appointment. You would be better off having a different technician from Sears come out to your house, as the one that came was not honest with you. Good luck, Mack
Posted on Jan 06, 2008
esanto2
  • 3 Answers
SOURCE: Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
If you have already tried shutting off for 24 hrs. (reset), cleaning the under-bed condenser fins (vacuum and/or compressed air) and the issue still continues, you may be lucky enough to just need a relay/overload switch; the thingy connected to the compressor, which by the way takes patience and ease in removing. However, once the plastic cover is off, simply unplug the relay switch(s) and shake it, if you hear rattling (or) smell burn, the relay is toast and thus needs replacement. Simple enough, for replacement type in the model # of the compressor: (i.e.) [[ Embraco FGS 80 with relay/overload switch ]] cost around ($30-$50)... order, replace, re-plug, and if on target, the compressor will kick in. let run for 24 hours before adding foods, and all is good. Have a nice day. ee
Posted on Dec 07, 2008
  • 40 Answers
SOURCE: fridge sounded like a car revving
Check the compressor fixation are okay.Normally it should be on rubber parts fixed to the bottom.If one of them is not fixed it can vibrate.
Posted on Jun 30, 2009
todd0708
  • 247 Answers
SOURCE: Kenmore model 596.52673202 refrigerator not cooling or freezing
the defrost should be controlled by a timer every 10 hrs or so,it is usually in the bottom of the fridge by the compressor,it has a small motor that turns the timer,they burn out
Posted on Jul 21, 2009
We have this fridge model, engel sr65e-g3-wh, and it is making a lot of ice, the whole fridge becomes icy, 13 yr old. What can i do, do you have spareparts to repair it or can i buy a new one
You are lucky it lasted this long. Replace it. Parts are not available, and if they were, the cost to repair the unit is far more than a new Fridge.
Feb 07, 2018 | Engel Freezers
My old Engel won't work on 12v but it runs fine
By the way , What is a Engel? New or old? Desktop or laptop?
Dec 09, 2012 | Computers & Internet
Engel 43 qt fridge freezer stopped cooling. the compressor comes on, the fan is blowing but not cooling
have you checked the compressorpump is getting warm(a sure sign its working.sometimes a little tap works)
Feb 11, 2010 | Engel 43 Qt.Portable Freezer.
I have an early grey model 39lt engel and it will not work on 12volt I was wondering if I could get a service manuall for it thank you
You will not find any service manual. You can try www.engelaustralia.com but I doubt it will help you. By the sounds of it your 12vdc oscillator is gone, it is usually a K3320 or similar on the old boards. On the new boards you would have to replace the board. G luck
Mar 17, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
35 litre Engel. Not getting cold.
can you feel if the fan is blowing air
Jan 21, 2008 | Refrigerators
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Refrigerators Logo
24 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
