Question about Epson Stylus NX130 All-in-One Printer
How to remove print head on Epson NX130 printer
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: epson stylus photo 2200 print head removal
Replace the cartridges.
Otherwise, it's unorthodox, but some users have found that this works in your situation. Remove the cartridge, cover the nozzle with a paper towel and use the pointed attachment of a vacuum to clean the dry ink from the cartridge. Be careful not to get ink all over. Then reseat the cartridge and print...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 26, 2009
  • 164 Answers
SOURCE: print head clogged
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Testimonial: "thanks v much for the well detailed procedure. If this works it will have saved me a few hundred pounds"
  • 50 Answers
SOURCE: epson sx210 inkjet printer trying
If you're using Windows,
XP : Click Start, go to Control Panel > Printers and Faxes Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Vista : Click Start, go to Control Panel > Hardware and Sound > Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
7 : Click Start, go to Control Panel > Hardware and Sound > Devices and Printers Right click on your printer, click Printing Preferences, click Ink Cartridge Replacement. Follow the instructions.
Posted on Dec 08, 2010
Epsom NX130 wont print after replacing new ink cartridge. Have taken all out turned off power. Not working
Does it try to print, but the page is blank, or does it simply sit there?
If it tries to print, but nothing comes out, you may have a clogged print head.
If it doesn't even try, did you use a genuine Epson cart, or an after market? Epson printers won't print if even one cart is empty.
May 02, 2015 | Epson Stylus Nx130 Mfc Inkjet
How do i scan using the Epson NX130?
Lift lid and place article to be scanned in.
Then click right on printer app /shortcut or inn device and printers
folder and you will see preview scan click on that and it will come a
s preview. It's common sense from there.
May 15, 2014 | Epson Stylus Nx130 Mfc Inkjet
Epson Stylus NX130
That's the problem with Generic carts. Use either Genuine carts or Resettable Carts.
Mar 04, 2014 | Epson Stylus Multifunction Inkjet Printer/...
How to change the ink for an epson stylus nx130 printer
Replacing procedure only available if one or more ink tank "empty" or not recognized. Follow "how to..." at epson status monitor. but if you wish to replace, just turn on printer, unplug power chord while carriage moving. The carriage released from locking position, move carriage by hand to the appropriate position.
Jan 20, 2013 | Epson Stylus NX515 All-In-One InkJet...
I lost my cd for installation for my epson stylus nx130/tx130 series printer
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 25, 2012 | Office Equipment & Supplies
Want owners manual for empson nx130/tx130 printer how to download
i just know this will help you:http://www.openprinting.org/printer/Epson/Epson-NX130_TX130_Series
tablette pc - netbook 10 pouces - apad 10.2
Feb 17, 2012 | Office Equipment & Supplies
How to remove epsom NX400 print head
The print head on the NX400 printer is integrated into the ink cartridge and therefore when you remove the cartridge you are removing the print head. . . If you want to clean the print heads / nozzles then see the procedure in the NX400 User Guide in the section for Adjust Print Quality. . . .The User Guide can be found at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Feb 21, 2009 | Epson Stylus R290 InkJet Printer
Epson Stylus NX130 All-in-One Printer Logo
161 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
