Need parts for QC888HB heater
Heater has a burned contact and starts and immediately shuts back down. Where can I purchase parts or another heater?
bbtoast
  • 319 Answers
SOURCE: shuts off after slowe burning ,8888 flashes, and all burner lights fash. Monitor 441 oil heater.
Have you looked at, and or followed the troubleshooting suggestions at this website?
There is a full troubleshooting guide for your model. Let me know if you have checked this site out, then give me more details as to any other indications.
How old is this unit, how long has it been plugged in to the current electric outlet, etc.
Thanks
Brian
Posted on Jan 19, 2008
SOURCE: quartz heater parts
I have an older presto quartz heater thats needs a thermostat the info on the switch is as follows
INF-120887B 34-191 15AMP 120VAC can anyone help me out? thanks fred
Posted on Feb 04, 2009
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
  • 188 Answers
SOURCE: Reddy Heater keeps shutting down
I tried to go to www.desatech.com and you cannot buy parts on that site anymore. I can get my Reddy Heater parts at www.masterparts.net.
Posted on Mar 06, 2009
SOURCE: Patio heater won't stay lit
I had this same problem - here's how I fixed it...
First: Never modify the safety features of your heater as has been suggested elsewhere on this forum. Modification of these features may allow the heater to work, but greatly compromises the safety of anyone near the heater.
The problem with the heater shutting off is most likely due to not enough gas flowing through the pilot orifice (this orifice is almost as small as the diameter of a human hair). When this happens, the pilot flame does not burn vigorously enough to activate the thermocouple. Hence, the thermocouple shuts off the gas and the burner goes out - usually you'll hear one "click" when this happens.
This is a maintence thing - meaning you may have to do this as a seasonal activity.
Here we go....
(1) Shut off the gas at the tank - or remove the tank entirely.
(2) Remove the screws that hold the burner shield and top shroud from the unit - set it aside.
(3) Remove the control knob - it just pulls straight off.
(4) Remove the panel immediately behind the knob you just took off. This will expose the gas valve assembly.
(5) Remove the cover that encloses the bottom of the pilot light/igniter (assembly). This will expose the bottom of the pilot assembly.
(6) Remove the screw holding the pilot assembly - there is a small hex nut on top, but under the burner that you'll have to hold to prevent it from turning. This will free the pilot assembly allowing you to gently pull it out of the pilot assembly housing. DON"T pull hard or you may break the gas line or thermocouple.
(7) Remove the hex nut that attaches the gas line to the pilot assembly and gently pull the gas line out. At this point, to ensure you have gas flowing through the pilot gas line, you may want to re-attach the gas tank, turn it on, gently move the gas line as far away from the spark ignitor as possible, temporarily replace the control knob, and turn the knob to the "Pilot" position & push it in. DO NOT DO THIS ANYWHERE NEAR AN OPEN FLAME OR A LIGHTED CIGARETTE! You should be able to hear a hissing sound as the gas flows. If you do not hear it, the problem may be with your gas valve, and if that's the case, I'm sorry this procedure likely won't solve the problem.
(8) Remove the pilot light tube (orifice) from the mounting bracket. There's a hex nut on the back side that holds it in. Be careful not to damage the hex nut or the threads. You'll need a pair of pliers (to hold the bracket) and an adjustable wrench for the hex nut. Make note of the orientation of the pilot burner diverter so you can put it back together the same way it came apart.
(9) Using a blast of compressed air, blow air through the pilot orifice. You should be able to see just a very (and I mean very) small pin-point of light through the pilot burner. If not, use a single strand of very fine wire - like one strand from a 18 gauge braided electrical wire - and run it through the pilot orifice. Carbon build-up can clog this orifice - which can prevent the pilot from burning vigorously enough to heat up the thermocouple. Cleaning it out periodically will likely solve the problem.
Put everything back together in reverse order as noted above - making sure your gas fittings are tight and don't leak. Once it's all back together, light the pilot flame as normal and once the thermocouple heats up, the heater should work like a charm.
Posted on May 25, 2009
Noma model ew7507ce
There is a thermal disc inside the heater that will tell the heater if it is getting too hot to shut down. When the disc cools off then the heater will start up again. After a wile the disc gets weak or it gets stuck open not allowing the heater to turn on. You will need to replace the disc or purchase a new heater as parts for those are not easy to find.
good luck
Apr 14, 2014 | Honeywell Heating & Cooling
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Spa heater starts up and then quickly shuts down in cold weather
check the air proving switch to see if blower is providing enough airflow. cold weather may be affecting blowers performance
Dec 05, 2013 | Sta Rite Pool & Spa
Need a thermostat for model no hz-514
How about a free replacement heater?
There has been a recall since 2002 on some Honeywell portable baseboard heaters. Check this link, or call Honeywell ASAP. The ON/OFF switch failed (with a burning plastic odor) on my HZ-514.
http://www.cpsc.gov/en/Recalls/2002/CPSC-Honeywell-Consumer-Products-Announce-Recall-of-Moveable-Baseboard-Heaters/
"Consumers should stop using these heaters immediately, unplug them, and contact HCP at (800) 290-8495 between 8 a.m. and 10 p.m. ET Monday through Sunday or log on to the company's website at www.honeywell.com to determine whether their heater is part of the recall."
I hope this is a solution for you, and you are safely warm again in the near future. need-thermostat-model-no-hz-514-gwybjxudtwjfkyidrgix5fxs-4-0.jpg CPSC Honeywell Consumer Products Announce Recall of Moveable Baseboard...
Feb 03, 2013 | Honeywell HZ514 Baseboard Heater
Having problems with models sutting down. Relates to combustion shut off system. Explain how system works, with corrective action, especially draft system. Pilot ignites, burner operates for second or two...
As a general rule with Rheem gas water heaters, the manufacturer suggests calling trained service technician and their products do not have specific service bulletins.
I cannot explain combustion shut-off adequately. Post question on water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/
Most likely the combustion and combustion parts need cleaning and maintenance, as a start point.
Gas water heaters today require yearly cleaning and maintenance.
That work would cover possible causes and combination of causes: from air in gas line, faulty venting, inadequate air supply, dirty parts, overheating, leaks, exposure to chemicals, corrosion, faulty gas control valve thermostat, sediment build-up.
You have a standing pilot light that is working, so gas supply sounds correct, and ECO is not tripped, so cleaning is major suspect right off.
Light a match under the vent hood and check if smoke drafts immediately upward.
Your water heater vent has a natural upward draft that pulls combustion by-product upward so the poison gas is vented outdoors to kill the world slowly instead of remaining inside the house. If vent is clogged, the air flow might not support combustion. Likewise if water heater does not have adequate incoming air supply, for example a tightly sealed house, then combustion is not supported. Also if you store bleach and pool chemicals and other assorted chemicals in trace amounts in same room or nearby, the burning chemicals will corrode combustion parts so they no longer perform.
http://waterheatertimer.org/images/Test-water-heater-vent-400.jpg
See general illustrations for cleaning combustion parts, and read 2 pdf files about cleaning typical gas water heaters.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Read Reliance gas water heater handbook. It may or may not apply to your circumstance and heater.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Jul 11, 2011 | Rheem 30 Gallon FVR NATGAS Water Heater...
I have a Lasko Model 5532 electric heater. It has suddenly started shutting off often. I run it through the reset procedure (unplug 5-10 minutes, then restart) and that gets it going again, but then it...
All of these space heaters have thermal protection units in them. They are safety that shuts the unit down if it starts to overheat.If your fan is operating, then it sounds like the thermal protection circuit is faulty, and you'll need to contact Lasko for a replacement. These units do not have parts that can be purchased due to their UL compliance. Check the fan though, it might be obstructed. I have seen that more than once....Rob
Dec 28, 2009 | Lasko 5530 Ceramic Compact Heater
1995 Cherokee heating (A/C) issue
sounds like you have a wire that has lost or burned off its cover and is grounding out the vehicle and has soon as its power is cut the wire breaks free from the bare metal and thats why you can immediatly start the vehicle
Dec 30, 2008 | 1995 Jeep Grand Cherokee
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
