Question about Epson Stylus NX330 All-In-One Printer
I have a epson stylus NX330 All-in-one-printer...with color cart...installed, i can only print in black, i need instructions on how to print, in color, i have a manual
My NX330 prints in black, i would like to print in color also, color carts, are installed, i have read the manual, but to no availe, please advise...
4 Suggested Answers
  • 59 Answers
SOURCE: Printing problems after changing Cyan and Magenta cartridges
What's going on is common with epsons. Nine times out of ten it happens when there is a cartridge change. You need to have the head cleaned out with fluid. Power it off when the head can be moved, such as when you tell it to change ink cart.'s take a small syringe with a bit of hose stuck to the head and purge the gunk out with a solution. I use 4 oz. 99% alcohol, 4 oz. ammonia and nearly a gallon of water. You might not need such a large quantity of this solution, but I use it a lot. Anyhoot, bring the solution to a near boil, and suck some up into the syringe w/ hose. Slide the hose over the part of the head that sticks into the ink cartridge and inject the solution. Do this several times until you feel no resistance from the printhead! Should be good to go then. It might be too far gone by now though.
Posted on Jun 08, 2007
SOURCE: My Epson RX620 black cart absolutely will not print
Problem Solved!!!!
I bought the special cleaning cartridge as suggested and it worked very well. My RX620 is working like new!
Thanks!
Posted on Jul 11, 2008
gwbm
  • 353 Answers
SOURCE: Epson C66 problem
Without the benefit of a response from any of rickyostrom, liusgarciaca, or hotdog233311, I think we can say the problem lies with the fact that your magenta cartridge isn't printing. You can confirm this by carrying out a nozzle check print.
If any of you would like further assistance in restoring your magenta to working condition, please do a new post to this effect.
Posted on Mar 02, 2009
Cannot print in color from my documents UNLESS I open it in Paint. Just get a blue line at top of page. Working fine for ages. Replaced all cartridges. Black is fine
If you can print in color from Paint, then it's not your printer.
When you go to print from your other applications, check all of the tabs in the printer set up area for "greyscale", and make sure that's not checked. Sometimes it will say, "black only" instead of "greyscale"
May 16, 2015 | Epson Stylus Nx330 Small-in-One Printer...
I have a Espon Stylus NX330, and my printer wont print, it has been in storage for a couple of years, now I have bought some cartridges and it wont print, it recognizes the cartridges but it dosent pr
Did you have the printer cleaned properly? This is a machine! It has moving parts - being in storage for prolonged periods will result in several conditions, dried lubricants/ silicon, corrosion, build up of dust, mold etc. It different from a new machine that came out of it package.
Oct 08, 2014 | Epson Stylus NX330 USB/Wireless-N...
Epson nx330 manual
download it here.. http://files.support.epson.com/pdf/epnx__/epnx__u1.pdf
Apr 22, 2013 | Epson Stylus NX330 USB/Wireless-N...
Will not print black
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 11, 2013 | Epson Stylus NX330 All-In-One Printer
I CANNOT PRINT BLACK ON MY EPSON STYLUS PHOTO R200. All other colors print. I have replaced all the cartridges. This is my forth attempt at trying to contact you people. CAN YOU HELP ME?
this issue may have several causes:
1. make sure that you've removed the yellow ribbon from the top of the cartridge before installing it. it is there to keep the ink fresh before it's installed and has to be removed to enable the ink to flow into the print head. (not all epson cartridges have this ribbon though)
2. check all the settings in the printer driver or simply remove the current driver completely and reinstall the latest driver you can find on the epson site.
3. the black print head may be clogged. in this case, performing cleanings will help, possibly several cleanings are necessary
4. there may be a faulty connection between the printer's mainboard and the print head.
5.there may be an electronical problem with either the print head or the mainboard.
in the last two options it's better to let a professional technician look at it.
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
740i is recognized and seems to be printing but nothing appears on page in either color or b/w. New black cart installed.
It sounds like the print heads are clogged and need to be flushed. This especially happens to printers that have gone unused for an extended period of time while still loaded with in cartridges. A local technician can probably flush these heads for you.
Nov 17, 2009 | Apple Epson Stylus Color 740i InkJet...
I have inherited an Epson R1800 printer that guzzles magenta and cyan inks like crazy. Am I doing something wrong?
No, If you are printing any coloured output this will be normal depending on the actual colour content and what most people don't realise is that unless your text is pure black then it will be printed using the color carts as well and not the black ink cart.
Oct 15, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R200 - print with black ink only
Nope.....
Epson will not print unless all carts have ink in them to some degree. If the light is on for any reason, printing will be halted.
For future reference, once the color carts have been replaced, you can set the printing defaults to print in either gray scale or BW only. Keep in mind that Epson printers tend to mess up if you don't use the ink at least once a week.
Aug 01, 2008 | Epson Stylus Photo R200 InkJet Printer
PRINT
Should be option on print driver ie Control panel/printer and fax's right lick on epson driver, properties.
Still needs a colour cart installed.
Nov 16, 2007 | Epson Stylus C82 InkJet Printer
Epson Stylus NX330 All-In-One Printer Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
