Question about Homelite Super Xl Automatic Chain Saw Parts Manual Part 24228 Rev. 1
What is difference in the Super xl 10045A, 10045B, and 10045C?
Need spec for numerical coil gap setting
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Chainsaw won't start when warmed up
Coil is possible, change the plug (cheap insurance) and try it. If problem persists try this shortly after it quits.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
An index or business card is good for gap tool. Remove the plug, rotate until magnetic attraction pulls coil and card tight to flywheel, then tighten coil screws. Rotate flywheel until magnetic attraction eases, remove card, rotate a couple of revolutions and ensure nothing drags or contacts flywheel.
Homies are bad for clogged fuel vents too. When it begins to sputter roll it onto side and loosen fuel cap. If ti smooths out and runs properly it has a clogged vent. HTH
Lou
Posted on Dec 22, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a 1979 Homelite XL Chainsaw model # UT
32:1 according to this.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/57a3b86d6acae4e188256c260048b728?OpenDocument
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 14, 2010
dkromo
  • 5 Answers
SOURCE: i have an old homelite
For the high and low speed jets turn all the way in and turn counter clockwise 1 1/4 turns to start with and continue a bit more until the saw runs a max speed(go by ear) and idling speed(idle down enough so chain does not spin while finger off triger). For the spark plug gap, go about 20 thousands of an inch. I hope this helps you out.
Posted on Jul 16, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Need to find contact breaker
Hi marie hourig...
Set your gap between .18 and .20...if you do not have a feeler gauge to get the clearance right, then you can use a paper match book cover...it is approximatly the same thickness as you need.
Please take time to rate me
Posted on Sep 13, 2011
How to test a coil in motorcycle
Hey Dan, There are a couple of resistance spec's..(they differ) ..We used to load check them (Yamaha dealership) with the "Electro-Tester".. this will simulate running conditions by loading the coil and making it jump a spark gap (adjustable with the tester).. we would wrap the coil with rags to get it hot and let it "run" for a while.. if it was bad, it would break down and not jump a 6MM gap.
Get your self a service manual..(Factory, Haynes. Clymer, Chilton) for the specs and take it to a dealer for further testing.
Aug 28, 2017 | Motorcycles
What is the gap between coil and magneto
I use a piece of A4 copy paper to set the gap.
Apr 05, 2015 | Garden
What spark plug to use in super xl auto mine doesn't seem to have enough power .
About .030". Remove the muffler if you can and look to see if the piston is all scored up. You may be using garbage gas or mix oil as well.
Jan 01, 2015 | Homelite Super Xl Automatic Chain Saw...
What iscoil gap on gx160 honda5.5
Call a small equipment dealer & ask
for the specs
Jul 14, 2014 | Honda Quincy 17 - Gallon Air Compressor...
I need clearance specs for the coil and flywheel
This isn't the most technical sounding answer but it works and I've used it numerous times with no problems. To set the coil gap on small 2 cycle equipment , I use a 3" x 5" note card, tighten the bolts then manually turn the flywheel to make sure it doesn't rub.
Oct 21, 2012 | Husqvarna 125B Blower
Need to find contact breaker points gap on super XL automatic chainsaw serial no 50832357 (old chainsaw)
Hi marie hourig...
Sep 13, 2011 | Homelite Garden
Need to set magneto gap on homelite super xl chainsaw model UT10045c
Hi, 8 thou is the correct gap. Hope this helps, regards Phil.
Jun 15, 2011 | Garden
I need a Service and Parts Maneul for a Homelite Super XL Automatic Model # 10045A, Serial # 301330028
Go to mymowerparts.com . They have a huge selection of parts lists available for free as pdf's. I have a 1983 Super 2, and I found one there. You'll have to scroll down a very long list, but stick with it. As for the service manual, good luck, I'm still looking for one myself . Surprisingly, your local library may be your best bet. Look under "chain saw repair" or "small engine repair". Also look for an owners manual, it has basic service information.
Jan 11, 2011 | Garden
I have a 1979 Homelite XL Chainsaw model # UT 10045C Serial # 3E1930093. What is the fuel mix ratio for this saw?
Lou
Apr 14, 2010 | Homelite Garden
What are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Mar 12, 2009 | Husqvarna Garden
Homelite Super Xl Automatic Chain Saw Parts Manual Part 24228 Rev. 1 Logo
53 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
