Question about Cub Cadet Garden
No power to the ignition switch on my lt1016
I turn on the ignition to start my cub and I have no power to the hour meter. Also it won't start. I put the battery on a charger to full charge with the same result.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Blown fuse
Posted on Nov 22, 2013
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I put a new battery in my cub riding mower (2166).
Look at all of the safety interlocks: seat must be down, drive must be in neutral, brake must be on, blades must be off, etc.
Gary
Posted on May 24, 2011
yakuzza2
  • 68 Answers
SOURCE: cub cadet model 1520 won't start.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Posted on Jun 11, 2012
Testimonial: "This all sounds logical to me and I had already checked to make sure the pto was off and consequentially no belt bind. Kinda leaning toward the key switch more so than starter I'll do some more checking and let you know .thanx for your suggestions."
How can I tell if my starter is bad on my cub cadet rtz mower
Check for spark
Have to get the test plug for small engines
Is the battery years old & partially dead?
Is the oil clean & full
Won't turn over or won't start?
Clean the flywheel & ignition coil or whatever
system it has for spark
Check for intake gasket leaks.
Did the meter always go down to 9.8 when it did start?
Your best to work on things & learn-- when they work correctly,
not wait for years then be lost
May 08, 2014 | Cub Cadet Garden
I have a 2004 Dodge Neon and I just replaced the battery and for some reason sometimes when I'm running a lot of errands when I turn it off it won't turn on again. It won't even make any noises...
Something is wrong in your start circuit. From battery to ignition switch, and ending at the starter solenoid. You would have to start checking for where power is lost between the switch and the starter. If you have power to the starter solenoid on the small wire at the starter (can check with a test light while someone holds the key in start), then the starter would need testing.
Jun 08, 2013 | Cars & Trucks
I replaced the ignition lock cylinder in my 92 cabriolet and I turned the key and it started first swing, then I was putting the steering wheel covers back on and it just turned off... When I try to turn...
If it's an automatic check fuse #15 wether it's a stick or automatic you should have power at the red & black wire coming out of your ignition switch when you turn key to start postion and power at the red wire going into switch at all times. if no power coming oit on the red/black wire you need an ignition switch. if there is power coming out of switch try putting car in nuetral (for auto trans). if still nothing you'll need to check for power at small wire going to starter when key is turned to start. if has power then need starter if no power you'll need to check starter interlock relay.
Dec 31, 2012 | Cars & Trucks
2003 toyota tacoma won't start
What was checked/tested ?
Fuel pressure at motor & spark cranking?
Battery seems fine based on what kind of testing?
Won't Start
Won't Turn Over
Have to get your thoughts around what you say
Nov 29, 2012 | 2003 Toyota Tacoma
Won't start.
There are a number of safety switches on mowers today for example one for the seat, pto (deck being engaged) There may also be a blown fuse as you said the hour meter is not working
Oct 23, 2012 | John Deere Garden
2001 jaguar s-type won't crank battery new and charged. Turn the ignition car won't make a sound
many things will cause no start problems could have faulty ignition switch.use test light see if power going to starter if not check ignition fuse to starter.if power going to starter, more likely starter solenoid or starter faulty.if ignition fuse okay and starter and solenoid okay still no start problem could be in the ignition switch or inhibitor switch faulty.code scan for faulty theft security system which will also cause no start conditions.
Oct 22, 2012 | 2001 Jaguar S-Type
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Cub Cadet LT1050-Replaced the solenoid, had starter checked out-it's good, battery has full charge, but mower won't start. Help!!
You need to check that there is a 12volt supply from the low tention wire at the solinoid when the key is turned, if there is not either the switch is bad, or the wire from the switch is bad, or the fuse has blown.
Mar 04, 2012 | Cub Cadet Street Sign- tractor lawn riding...
My cub (GT2186-44) starts up but immediately shuts down after you release the ignition switch. The engine is pumping fuel but is not getting to the carbuerator, I tried replacing the ignition switch &...
if what you are saying is true that it starts and runs till you let off the key, then your ign switch is at fault. check this with a test light or d.v.m. to see if your coil + has 12 volts to it with the key in the RUN position. sometimes I have seen power while cranking then when you release key the power goes out..or eng stops cause switch doesn't have power to coil in RUN position, keep in mind there are lots of different Ign switches out there, make sure you replaced it with the right kind, use your test light to diagnoise
Jul 27, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
91 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
