Question about Technics Audio Players & Recorders
My sl1200 turntable seems to be putting out static i can hear the stylus play but no musik coming through the rcas???
  • 7 more comments
  • niknpaul Mar 12, 2009
    ??? what do you mean could be cut? when deck is plugged into mixer even when off. produces noise from speakers from that channel. tried different channels???
    where is that and how do i clen it?
    turntable is in phono earth is grounded, static gets loader when you touch the turntable anywhere, and still does it when power is off to turntable??
    the noise is there with no record doesnt even need to be on???
    it was fine till the other day set up exactly the same. the ground is connected to ground on back of the mixer? needle is approx 6 months old. i can swap turntables and does the same in the other channel where my good turntable is fine in both????
    ?? do you mean check rcas where they connect to turntable??
    does it sound strange for that to just happen. it was fine?
    did u say the ic is approx $3 where do i find one
    rca wires are fixed to the turntable??
    Genius:
  • 1,239 Answers
Hi check these if any suits to u  Problem: No audio output, audio cuts in and out or only audio from one side.
Possible Cause 1: Dirty stylus, worn or faulty stylus or cartridge. Solution: Try cleaning stylus tip with a stylus cleaner (such as Stanton's SC4). See link.
Isolate and replace the defective stylus or cartridge.
Possible Cause 2: Loose cartridge or headshell connections. Solution: Check cartridge connections to headshell wires, making sure that the colored wires don't have any breaks and are connected to the respective cartridge pins.
Possible Cause 3: Oxidation or dirt build up on 4 pins in the toneam that make contact to the headshell. Solution: Clean the 4 pins using a pencil head eraser and then with some rubbing alcohol on a Q-tip
Problem: Digital output not working.
Possible Cause 1: Incorrect output connections. Solution: Make sure to connect the turntable's SPDIF digital output to a computer sound card or stand alone CD recorder that has the same single SPDIF or coaxial input.
Possible Cause 2: Digital recorder or sound card spec don't match. Solution: Make sure the recorder or sound card specs match the specs of the turntable's digital output: 44.1kHz sampling rate, 16 bit word size, PCM format.
Possible Cause 3: Wrong digital cable used. Solution: Only use a SPDIF or coaxial type digital cable with a 75ohm load.
Problem: Cartridge skipping.
Possible Cause 1: Incorrect tonearm and cartridge setup. Solution: Properly setup tonearm and cartridge settings as specified in turntable owners manual or cartridge setup instructions. See link.
Possible Cause 2: Worn out or damaged stylus. Solution:Replace the defective stylus with a new one.
Possible Cause 3: Dirty, worn or scratched records. Solution: Clean records using a vinyl cleaner (such as Stanton's VC1). See link.
Use records with little or no wear or scratches.
Possible Cause 4: Turntable not level. Solution: Make sure turntable is placed on a sturdy and flat level surface.
Problem: Audio feedback.
Possible Cause: Turntable to close to speakers.
Solution: Face speakers away from turntable or move turntable away from speakers signal wave path.
Posted on Mar 12, 2009
    Sergeant:
  • 254 Answers
Its the problem of amplifier ic in the turntable that is actually fried up.that controls the sound variations which passess through the speakers. the ic number IC563JI  has to be replaced from the amplifier board which is in the unit.and new $3 IC  has to be replaced.this will solve the problem.try to do manually onlky if you are familiar with soldering iron and multimeters other wise its a repair person job.any ways the cost will be negligible.and its worth reparing.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Always, a turntable has an additional ground wire that connects to the chassis of the amp/receiver. This is aside from the regular RCA shielded wire.
Offhand, your post 'static gets loader when you touch the turntable anywhere' is very significant. This indicates that the braid part of the shielded wire as well as the ground wire is not doing its function. This could mean that they are cut or disconnected. Solution would be to check/replace the ground wire as well as the shielded wire with the RCA plugs.
Good luck and thank you for using FixYa.
    Sergeant:
    Champion:
  • 435 Answers
Try different are new RCA cables.
If its still doesnt work, Check if the RCA sockets are internally disconnected inside the receiver.
    Sergeant:
  • 320 Answers
When you say static, I take this to mean the stylus is picking up a lot of dust & producing some nice rice krispies sounds?
Earthing the deck normally only reduces noise & electrical hum. A carbon fibre brush is good for removing dust & static from a record.If your stylus is staticaly charged try cleaning the tip with some appropriate stylus cleaner or even play or place the stylus on a damp record for a few mins may help it discharge.
Try removing the earth connection from the amp & see what happens.
    Genius:
  • 1,550 Answers
It seems the volume control potentiometer needs cleaning .
  • 4,472 Answers
Make sure your going into a PHONO input on a reciever. If your using a regular rca stereo input it won't work. It has to be PHONO. Then make sure that the turntable is grounded to the reciever or mixer. To do this locate the grounding screw on the turntable and locate the ground on your reciever. If your still having issues and your doing all of this please let me know and I will assist you further. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • 2 more comments
  • Lee A.
    Lee A. Mar 12, 2009
    Usually if you can hear static it means your either not using a phono input or your not grounded. one or the other. If both those fail then you need to check the connection on your stylus. I think you have enough to go on I look forward to hearing back from you and will greatly appreciate a positive rating.
    Thanks again,
    Lee
  • Lee A.
    Lee A. Mar 12, 2009
    If it is doing it when it is off, then it is not properly grounded and that is what your hearing. How old is your needle? Also how do you know that your ground is actually grounded?
    Thank you,
    Lee
  • Lee A.
    Lee A. Mar 12, 2009
    Have you tried a different receiver/stereo, the phono input could be bad on your stereo. Basically you will want to go down the list of things that it can be and use process of elimination as that is the only way you will find what the problem is. I really hope you have found this helpful and will reconsider and accept and give a helpful rating. If you need further assistance I will be more then happy to.
    Thanks again,
    Lee
  • Lee A.
    Lee A. Mar 12, 2009
    Have you tried a different set of RCA wires? Also by what you have previously posted. I assume the ground wire is good and properly connected.
    Thanks,
    Lee
  • 583 Answers
Check out the connections it might be cut in between.
Picks record ,clicks twice ,returns record without playing
Mechanism for moving arm over and onto record is fubar. Probably stuck and the clicks you hear are the motor fighting a losing battle and returning arm to rest mount.
Remove stylus and play with arm and simulate turn on cycle to see how it works and where the jam is- fix and then put stylus back in - those little suckers are expensive.
Dec 06, 2015 | Audio Players & Recorders
My crosley keepsake turntable has been having a lot of static and the sound is very low, I can only hear it if I turn the volume all the way up. I'm not sure if the needle is the problem or there is s
I would check the wires to the cartridge. It might that one or more is off or loose.
If you turn down the volume completely and listen with a record playing you should be able to hear (with your ear) the stylus in the grooves of the record playing the track. Pick a loud (rock) record for this. If it does that OK the stylus is good.
Dec 26, 2014 | Crosley Keepsake USB Turntable
I just replaced the stylus on my sony PS-LX300USB turntable, but now there is a constant static on even my new records
You have either knocked the connections to the cartridge causing a loose connection, or not seated the stylus right. Or you have static build up, which can be caused by poor earthing.
Mar 12, 2014 | Sony PS-LX300USB Turntable
I use my Sl1200 with Serato and the other day one of the decks was starting slow. I solved the problem by spinning the record first and then placing the stylus down. But I want it to go back to the way...
p { margin-bottom: 0.21cm; }
HI,
After long years of use the electrolytic capacitors in the circuitry will get slightly change its value. If so it can affect the speed of the turntable. Its better to replace all the electrolytic capacitors in the turntable's electronic circuit board. It will not coast a lot for all the capacitors. Will only come around $3 or $4. .
OK
Oct 28, 2011 | Technics SL-1200MK2 Turntable
Well im not too sure if my needle is broken but when i play a record i cannot hear sound and it sounds like my record is being scratched. Do i need to keep the white cap on the needle or not? or is it just...
It's called a stylus. What red or white caps are we talking about? Some phono cartridges come with stylus guards that flip up out of the way for play or down to protect the stylus from damage while in storage or during tonearm balancing. The stylus needs to touch the record groove directly.
Jul 14, 2010 | Numark ttUSB Turntable
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
Trouble with sound
Confirm that the stylus you bought is spec'd out for that turntable
Also check all four wires to the cartridge
Mar 13, 2008 | Pioneer PL-990 Turntable
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
