Question about U-Line 29R Compact Refrigerator
Once the fridge reaches set point it won't run again until I turn unit off and back on again
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
You need a new thermostat
Posted on Nov 22, 2013
2005 V-6 mustang , fuel pump will not run
it's designed to only run until it builds a specific pressure. once the pressure is reached it turns off. if the car isn't running and you suspect the fuel pump drop the tank take the fuel pump out. use two pieces of wire and hook it straight to the battery and see if it continues to run. if it run continuously thats is not your problem as it will continue to run trying to build up pressure but it won't be able to considering it's not in an air tight system
Jul 16, 2012 | Ford Mustang Cars & Trucks
Ford taurus 2001 car start but once the car is cut off it won't start up again until it cools off the car is not running hot.
After you kill it, when you try to start it back up, does the starter turn the motor? Or is it froze up (will not turn over)?
Mar 12, 2012 | 2001 Ford Taurus
I purchased a 65 pint LG dehumidifer # LG LHD65EBL. This is the second one that I have had. I had to return the first one because it would not shut off when bucket was full. This one runs for about a...
First, tunr the unit OFF and unplug it for 10 minutes. Then plug it back in and turn it ON. It will automatically set at 70%. Press the - button and lower the humidity extraction level to 45% in increments of 5%. Once you reach 35% press and the - button one more time. Now the unit is set to run continuously, until the bucket is full and the unit turns OFF automatically or you manually turn the unit OFF. In case you have misplaced the Owner's Manual, I have included a link to it, that you can download and print. http://aic.lgservice.com/gcsc/dwn/main
I hope this helped you and thanks for choosing FixYa..
Jul 29, 2011 | LG LHD65EBL Dehumidifier
Can i set it to a temperature that will allow it to turn on and off automatically
Any temperature you set it at, the AC unit will turn ON and OFF automatically. Once the set temperature has been reached and held for 5 minutes, the unit turns OFF, but the fan may continue to blow for a few minutes. When the room temperature rises above the set level, it will automatically turn ON again and continue to run, until the set temperature is reached and it turns OFF.
I really hope this has helped you and thanks for choosing FixYa.
Jul 21, 2011 | Whirlpool ACQ158XP Wall/Window Air...
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
The dehumidifier shut off automatically but will not come back on. Model M7DH45B2A
If the unit shut off automatically, because it had reached the humidity extraction level you had it set on. It won't turn back ON again, until the humidity level rises above the setting you have it on. Lowering the humidity extraction level to 32 -35%, should make it start up again and cycle like it should. If your unit does not have an LED Screen, set the manual control on Maximum.Be sure the bucket is not full and the air intake filter is clean.
Hope this helped you to troubleshoot and solve the problem.
Jun 28, 2011 | Fedders A7DH45B2A Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
Cant get rs 125 to run because mixture screw needs setting
hi this might help,general rule of thumb on a two stroke is turn the screw all the way in untill it seats,then back the screw out 2-2 1/2 turns,this should enable the bike to start,once you have the bike running,set the idle to about 1500-2000rpm.turn the mixture screw in untill the engine starts to labour,then turn the screw out once again untill the engine starts to labour,what you are looking for is the "sweet spot"between these two labour points,this "sweet spot"will be where the engine revs reach their maximum,you will probably now have to back the idle screw back to a sensible idle,thats all there is to it..hope this helps...cheers
Apr 14, 2010 | 2006 Aprilia RS 125
U-Line 29R Compact Refrigerator Logo
60 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
