My leem kp-640s amp has no sound
It comes on but has no sound
Lines across screen & no sound
KP 53v80 is way too old to be fixing---recycle it as most landfills will not take that as it has toxic Glycol inside of it.
Apr 29, 2012 | Sony KP-53V80 53" Rear Projection...
I have just puchussed sims 2 for pc and was not told it wont play on windows vista, it keeps telling me i can download a program to play it. Not sure which 1.
When I tried to install The Sims 2 on my pc while using Windows Vista I had a problem. When the installation reached 1% a message appeared saying: "A problem occured when trying to transfer the file 'F:/Support/es/Leeme.txt' from the media. Do you want to retry to copy the file,or cancel the installation?" and the installation couldn't go on because you had only 2 choices, retry or cancel. The problem actually is with the name of the file. In the cd/dvd the file has the name 'Leã©me.txt' but in the installation the file has the name 'Leeme.txt'. What you really have to do is:
1.Open 'My Computer'
2.Right-click on the cd/dvd drive with the game in it and hit Open
3.Copy all the files of the game 4.Go to desktop, right-click and hit New<Folder.Rename the folder Disk 1
5.Paste the files of the game inside the folder
6.Go to Support<es and rename the file 'Leã©me' into 'Leeme'
7.Go to Support<sv and rename the file 'lã¤smig' into 'lasmig'
8.Remove the cd/dvd from the drive
9.Start the installation from Disk 1<AutoRun.exe
The installation should now work properly until the end.
But when you try to run the game a message will appear saying 'This program has known compatibility issues'. Click check for solutions online and then follow the link that appears.This link provides you with a patch for the game!
Aug 06, 2011 | Video Game Consoles & Games
Sony KP-41T65
is there a cadence to the blinking timer light?
Jul 17, 2009 | Sony KP-41T65 41" Rear Projection...
Blinks 6 times kp-51hw40
Look here and see if it sounds like the solution could help you.  http://www.fixya.com/support/t129700-green_flashes_tv_turns_off
Good Luck!
Feb 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Leem power mixer spare part
Have you tried a 2sd6041? sometimes japanese trannys use this prefix.
Sep 17, 2008 | Car Audio & Video
Leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Sep 09, 2008 | Car Audio & Video
Sony KP-53S35 "pulsating" Power Problem?
Sounds like youre needing a new D board. If you would like a link to where you can get a new board let me know and I will post a link
Jun 14, 2008 | Sony KP-53S35 53" Rear Projection...
Bass
hey again, still keen to talk to you about your amp. How much do you turn it up before the problem starts.
May 18, 2008 | Audio Players & Recorders
Sony projection tv Model kp-61h510
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2007 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
Electro Med Services...
