The E3 error code displays when an Abnormal Operation Protection Error has occurred, and activates to protect the unit from damage. This error code will require service.
https://www.youtube.com/watch?v=dkMCdjJdKRs
The E1 or E2 error code is an Auto-Stop Protection Error, indicating an issue detected by a sensor. This error code will require service. The E3 error code displays when an Abnormal Operation Protection Error has occurred, and activates to protect the unit from damage. This error code will require service. https://www.lg.com/us/support/help-library/e1-e2-or-e3-error-code-CT10000014-1340721215523 In this case, you need to drain water and remove the laundry. Then, run the rinse mode to clean the drum. Next, start the technique to make sure that the OC error has disappeared. If the washing machine is not correctly connected to the drain hose, OE, OF, E3 will appear on display.
https://all-errors.com/samsung-washing-machine-error-code-e3/
High Temperature Error - Software (Fatal Error) The temperature inside the fusing unit exceeded 225°C (437°F) for more than 1 sec. ? After this error has occurred three times, the machine will shut down and must be released with the Smart Organizing Monitor and serviced by a service technician. ? Main board defective ? PSU defective (TRIAC short) ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
E2 is your printer is out of paper or paper does not feed. E 2.X is an error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power
supply. After a while, plug the power cord of the machine back in and turn on
the machine. If the same error occurs, then the printer needs servicing or some repairs.
Try unplugging it for 10 minutes. While unplugged, press and hold the start and stop but for 10 seconds. Double check for any paper jams. Just the smallest piece can jam it up. There should be a list of error codes for anything wrong. List paper jam would have an error code, change toner, change or clean ink, ect. Is this the only message you get? If that's so, try the steps I mentioned above so the machine resets itself. It the problem still occurs, let me know I will gladly help you to correct this problem.
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom
E002/E000/E003/E261/E733: due to AC line noise.
Description
E002/E000/E003/E261/E733 occur due to AC line noise. If the above error codes are frequently recorded in the error log, they might concern AC line noise.
Cause
When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times.
Field Remedy
Replace the Switching Regulator PCB ***'y with a new one. 120V: FH3-2613 220V/240V: FH3-2614 The circuit has been modified to resist a noise.
REMEDY
Caution Press (* then 2 and 8 together then *)you are in service mode monitor:To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
call service. how to prepare the hardrive, any software, which OS
