Question about Powercom Smart King UPS System
Fault on smk-2000a UPS
Hi, my smk-2000a(smartking 2000VA) ups is faulty, some of the driver transisters blew on the pc board, does anyone have the circuit diagram for this ups? Some of the transisters cannot be identified I need a circuit diagram to repair it.
Thanks
Steve
    Scholar:
  • 64 Answers
I sell that product, I can a PC board for that product for you. Have it shipped directly too you.
No since in repairing a damaged board when it does not cost an arm or leg. You might want to use the old board for parts later on.
Make sure you take a digital picture of the set up before you remove the board.
Power com is an awesome and very durable product, blowing a that board, you might want to do something on the AC power like a surge suppressor. If you are using a back up generator on the system, then over current might have done it. So call me, I can help you. I have more questions for you, so this problem will not destroy your PC board again.
www.storminprotection.com
727-823-6100
Posted on Sep 08, 2009
3 Suggested Answers
hmerchant110
  • 7191 Answers
SOURCE: UPS TROUBLE SHOOTING 2000VA/1200, RED
Your problem dated 12th Jan 2011 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks.
Posted on Feb 13, 2011
uk8ahw
  • 3 Answers
SOURCE: ups is not glow any indication, just give buzzer
It look like dead battery. Try to connect carefully new (or allmost new) battery with 24v lamp in (+) wire. If UPS alive - you'll see only small momentary sparcle. After this - connect battery as usual and try to turn system on. Be carefull! If lamp lit in full power - it means a serious internal problem. Best solution - look for qualified serviceman. (maybe yoir system needs reprpogramming).
Posted on Apr 14, 2009
UPS not working
check the batteries are still good and not expanded and split the sides or ends
Aug 17, 2016 | APC Smart-UPS RT 2000VA UPS System
Apc smart ups rt 10000 internal fault, what to look for?
you should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
Can i use 150 am 12 va battery with 2000va microtek inverter
You can use any size you want, just your UPS can charge the battery.
You can also add an extra charger in special cases.
If your UPS calculates backup time, you need to tell how big the UPS batteries that you have ...
Aug 19, 2014 | Computers & Internet
Smk-2000a battery replacement
The easiest way is to open the UPS and look for the battery fitted in there now.
May 22, 2014 | APC Smart-UPS 3000VA USB & Serial...
Looking in to purchasing a Ultra Xfinity 2000VA 1200w UPS ULT33046.....wanting to know how many batteries it contains to see what future costs might be....
It contains two universal #1290 9AH batteries with F2 connectors. The batteries are taped together side by side with the terminals in a vertical straight line so that the positive terminal of one is at the bottom left position, the - to + shunt connects the two middle terminals, and the negative terminal is at the top position. Be sure and write down the names of the connectors that the battery cables connect to on the board before you remove the batteries. There are two possibilities for both the positive and negative terminals.
Feb 14, 2013 | Ultra Products (ULT33046) UPS System
Hi, i am a technician attending an AEC UPS model ST4200, capacity 20KVA, the problem is that it is displaying :charger faulty: how can i solve this problem?
First I would check the fuses. does it try and ramp up at all? the charger board may have a bad fuse or may be faulty. Also check the batteries. Load test the batteries. Faulty batteries can lead to a fault in the charger. Also check the caps. Most people forget this because they are most often hidden way in the back out of site.
Oct 21, 2011 | Computers & Internet
It worked yesterday perfectly well. But today, i just switched on the UPS, then switched on the monitor and the UPS went off but the PC is still on. I then disconnected the Monitor, Now the UPS is on but...
Seems that the UPS has failed and so cut off power to the monitor. So please check your connection once again. The PC and the monitor must be given to the UPS and if the PC stays ON then the monitor must get power. So connect them to direct power to confirm if there is a fault, if so the power supply section would have failed.
now check on the UPS , check the battery on the UPS, is low it can disconnect. If so replace. Other wise the driver MOSFETS could have failed or a possible fault in the mother board.
Jul 29, 2011 | Acer AL1717 17" LCD Monitor
Surt10000xli not switching on
my ups surt10000xli ups shows internal faulty LED On, i have checked main board but couldn't find the fault. please tel me the fault
Feb 15, 2011 | APC SURT1000XLI 1000VA 700W 230V UPS...
Ups is not glow any indication, just give buzzer sound , APC make 2000va RS model kindly tell me what i can do to repair it.
Apr 13, 2009 | APC Back-UPSĀ® CS 500 UPS System
Powercom Smart King UPS System Logo
234 people viewed this question
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
