Which burner is it that is giving you problems? Front, rear, right, left?
Testimonial: "It's the front right burner. By dual purpose I mean it has a switch where I can toggle between a small burner (inner circle) or a large burner (engages the outer circle). It seems that when the burner is turned on with the outer circle engaged it will only heat to its max capability, never allowing for a low heat."
SOURCE: One range top control only goes to hi. Has no low
pudiera ser que el teclado se alla desgastado por uso normal o que se le allan derramado liquidos sobre el teclado
Please keep in mind, I'm not familiar with appliance repair so I need to ask for specifics if I'm going to try and repair this myself. Please!
