Question about Icon Image 17.5 S Treadmill
Image 17 r start problem surges once then stops
Barely surges then stops,no error codes nor does it trip reset switch
Heat Surge Reset Switch switch keeps tripping.
If The reset switch is tripping on a Heat Surge heater you need to take it to a qualified Heat Surge repair facility.
Feb 17, 2015 | Vacuums
Tip
Whirlpool Calypso Washing Machine Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR- Press STOP/CANCEL to clear the display and completely cancel the cycle.
FL - Flood Condition - FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
ER - Processor Reset Error - This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
LF - Long Fill - If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
CE - Communications Error - If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
  • Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
  • Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
  • Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
  • Drive motor thermal protector has opened.
  • Motor controller is not powered or fuse has opened. Replace motor controller.
LD - Long Drain - LD flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
CA or CL - Average current limit or Instantaneous current limit - If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or CL for instantaneous current limit trip.
  • Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
  • Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings. This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
OB - Off Balance - If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an OB for Off Balance.
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
SR - Stuck Relay - SR signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
LS - Lid Switch Error - The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display.
on Jul 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Fifth wheel air conditioner has error code E1 on thermostat, how do i fix?
Somewhere in your manual you should have a table telling your what the codes mean. I have no idea. Once you find out I can most likely direct you in how to fix it.
Sep 02, 2014 | Dometic Rooftop RV Air Conditioner
How to get fault coedes of a harley 2013 sportster custom
To enter diagnostic mode press and hold the trip odometer
reset switch while turning the IGN ON.
2. Release the trip odometer reset switch. "diag" will appear
on the odometer display.
3. Press and release the trip odometer reset switch. "PSSPtb"
will appear on the odometer display.
4. PSSPtb indicates the different modules that could display
codes if equipped.
Table 2-1. Modules That Set DTCs
DESIGNATOR MODULE
P ECM codes
S TSM, TSSM or HFSM codes
SP Speedometer codes
t Tachometer codes
b ABS codes
5. Quickly press and release the trip odometer reset switch
to cycle through the letters. The letters will flash as they
are selected.
6. Once the corresponding letter is flashing to the desired
module press and hold the trip odometer reset switch.
7. If no DTCs are present, "none" will appear on display.
8. If any DTCs are stored in the module, either current or
historic, they will appear on the odometer. Quickly pressing
and releasing the trip odometer reset switch will cycle
through the stored DTCs.
NOTE
The ECM will show "no rsp" if the engine stop switch is not in
the RUN position. Verify the engine stop switch is in the RUN
position.
9. If odometer displays "no rsp" then the motorcycle may not
be equipped with the module. If the motorcycle is equipped
with the selected module then go to other modules and
look for applicable communication codes.
10. When all the DTCs have been cycled the odometer will
display "end".
11. To clear all the DTCs in that module press and hold the
trip odometer reset switch. If DTCs are not to be cleared
quickly press and release the trip odometer reset switch.
The part number of the module will be displayed.
12. Press and release the trip odometer reset switch again to
continue to the next module.
13. Turn the IGN OFF to exit diagnostic mode.
Jun 24, 2014 | 2003 Harley Davidson FXSTD Softail Deuce
Asko d1756 power trips when door is closed
The switch in the door may have a bare wire touching the sides causing a short. Check a schematic for the proper way to remove and test the switch. Look for bare wires or any insulation cracks.
Mar 15, 2014 | Dishwashers
My washer begin washing but the stop and has the code lp what sim to be the problem?
This are the only codes for your washer. hope this help. WHIRLPOOL Calypso Washing Machine Failure Code Condition Check/Repair "PF" Power Failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. "FL" Flood Condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Press STOP/CANCEL to clear the display. "Er" Processor Reset Error This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. "LF" Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display. "CE" Communications Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display. "Ld" Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display. "CA"
"Cl" Average current limit Or
Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either "CA" for average current limit trip or "Cl" for instantaneous current limit trip.
Press STOP/CANCEL to clear the display "ob" Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
Press STOP/CANCEL to clear the display. "Sr" Stuck Relay "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
Press STOP/CANCEL to clear the display. "LS" Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Feb 07, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Haier AC Won't start
I had the same problem with a different model. I tested the cord, it worked, but still would not turn on. Well, after two days my friend and I decided we would try to replace the battery in the remote---it worked! Try your remote battery.
Jun 01, 2010 | Haier Mechanical Air Conditioner HWF05XC7
What is meant by error code SC 403
From the service manual:
SC403: Transfer belt position sensor error
-Definition-
The transfer belt position sensor does not activate even if the transfer belt clutch has rotated once.
- Possible causes -
• Main motor/drive malfunction
• Transfer belt position sensor defective
• Poor transfer belt position sensor connection
According to the manual, provided there isn't a major problem with the machine, you can reset the service code by turning off the MAIN POWER switch for a 10-seconds and then turning it back on. This should reset the code provided the problem doesn't reoccur. NOTE: The main power switch is a rocker switch on the front or left side of the machine, not a push-button switch up on the control panel.
Probably not a big help, but hopefully at least a little. I can't offer you much better advice, as I don't work on machines of this age, sorry.
Jan 20, 2010 | Ricoh Aficio 450 Copier
My AR M160 digital imaging copier keeps blinking with 4H showing and I cleared the paper jam, all intact, and now nothing but the blinking 4H. please advise
H4 (and other) Error Reset Code:
Press "clear" "interrupt" "0" "interrupt" in succession and machine will blank off
Using the numeric keypad make the display read "14"
Press the "copy/start" key
Good Luck
Nov 09, 2009 | Sharp AR-M160 Black and White Copier
C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Dec 04, 2008 | Copystar CS-1505 Copier
Icon Image 17.5 S Treadmill Logo
Top Icon Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Alienware X51
Alienware X51
Level 1 Expert
Are you an Icon Exercise and Fitnes Expert? Answer questions, earn points and help others
