Question about Samsung RF4287HARS - 28 cu. ft. French Door Refrigerator
Samsung french door fridge RF4287HARS
My samsung fridge is 1 1/2 years old. I changed the water filter and then when reset I got a code E5. I had repair man change the circuit board, and still had the same code. He said the compressor was going not that he checked it in anyway. The fridge worked for a week and then the freezer defrosted, I had to uplug it and leave it sit , I plugged it back in and it worked for another week or so and the freezer defrosted again Also everything in the fridge got warm. I unplugged it again and plugged it back in and so far still working, How do I fix this, problem.
4 Suggested Answers
  • 91 Answers
SOURCE: Samsung Refrigerator with bottom freezer model #
Check for ice build-up in and around the freezer fan where the blades are, if you can see ice in there (some times it may look like white foam but dont be fooled, it will be ice), the fan will be hitting it, defrost the freezer and check defrost element, (you will have to dismantle freezer section to get to it but reletively simple job) disconect from mains first. Good luck
Posted on Dec 19, 2010
  • 884 Answers
SOURCE: i have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
Posted on May 20, 2012
  • 884 Answers
SOURCE: samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Replace noisy freezer fan on samsung rf4287hars
fan is in the freezer behind back wall, and it needs to be removed to access the fan motor .
Aug 29, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
I would like to not use the filter.do i need a bypass plug to water filter on ffhb2740ps ?
Yes, you can get them on Amazon. for around $ 17.00 get the number off the filter before ordering one or two as the case maybe
Aug 26, 2014 | Frigidaire FFHB2740PP 26.7 cu. ft. French...
Need to replace the water inlet solenoid
The Samsung side by sides and french doors have split systems meaning both freezer and ref have evaps. Your water reservoir could be frozen. They have DC heater that is attached to reservoir so it does not freeze, this could be your problem. The other problem that I have run across is the water line in the door can be frozen. If it is the door, you can check by locating where it enters the door, because it will have a quick disconnect. Disconnect water line and grab a cup and place cup under diconnected line coming from cabinet on the door and press or have someone call for water on fountain. Let me know if that helps. Thanks Logan.
Apr 07, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Water flows very slow out of the dispenser on my samsung refrigerator
Try replacing the filter again, If it works again then you might want to think about putting some sort of water softener system in your home
Dec 08, 2013 | Samsung 26.0 cu. ft. French-Door Bottom...
Refrigerator RF323TE how do I change the water filter?
The filter for the french door refrigerator is probably behind the vegetable drawer, if you do not see it in the upper right hand corner of the refrigerator compartment. Remove the veggie drawer and turn off the water coming into the refrigerator. Rotate the old filter to the unlocked position and remove it. Then take off the protective cap from the new cartridge and insert it into the refrigerator. Rotate it to the locked position. (Rotate the filter to position the label before you insert the filter. Then the filter goes in correctly.) Reinsert the vegetable drawer and close the doors. Then turn the water back on and fill several glasses with water to clean the filter. Pour that water down the drain at your sink.
For pictures of how to hold the filter, see http://www.samsung.com/us/support/owners/product/RF323TEDBSR/AA . See the FAQ on replacing the water filter. I hope this helps.
Mar 31, 2013 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Samsung RF4287HARS - 28 cu. ft. French Door Refrigerator Logo
44 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
