Sony KP-FW51 picture is fading 10 beep code indicates transistor or leaky board
2 Suggested Answers
  • 8909 Answers
SOURCE: Sony Projection TV WEGA KP-FW51 The
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Posted on Mar 19, 2011
I have a Sony Trinitron KP-43T90, have sound but no picture it is a 2001.
Check its horizontal output section circuit for fault. Check the horizontal output transistor. If it found leaky, suspect horizontal output transformer.
Dec 21, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Projection TV WEGA KP-FW51 The indicator lamp flashes 10 times. Sometimes the tv turns on (sound only) and then switches off. Now it does not turn on at all. Chris
Mar 19, 2011 | Sony Televison & Video
Sony kp-46wt520 standby light flashes 10 times. Does not power up.
hello Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
shaun
Dec 27, 2009 | Sony KP-46WT520 46" Rear Projection...
Need information on a "Code 10" for a Sony Projector TV KP-57WS520
hello - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
shaun
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Hav a sony kp 61hs30 need horz output. number on part MB12-140. is this a regular trans
Correct number is 1MB12-140 (Q8038) on D board of Sony KP-61HS30, its part number is as follows..
Q8038... 8-729-038-10..... TRANSISTOR 1MB12-140-F153A
Available in Part Store.
It is Insulated Gate Bipolar Transistor, click here to see its details.
Thanks.
Oct 23, 2009 | Sony Televison & Video
Sound comes on, but know picture then unit shuts off. Standbye light blinking 10 times pause then cont. 10- kp51ws520
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.good luck
shaun
Aug 26, 2009 | Sony KP-51WS520 51" Rear Projection...
TV blinks and won't turn on
Check Q8014 and Q8013 for short,leaky componets and poor solder connections onD board and If the transistors arre bad ck R8015 and IC8005 on same board.
Dec 17, 2008 | Sony KP-57WV600 57" Rear Projection...
Kp-65ws500 RED
Sounds like a Cathod Short in the red CRT. May also be a CRT Board or a Video Chip heating up. To check for heat problems I use a canned agent called freeze spray. You can spray it on the boards and if the problem quits, the problem is in that board, then isolate it to a component ( transistor, chip capacitor etc). Good luck
Ed
NC Electronic
Mills, Wyoming
Dec 26, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
