Question about Lakewood Economy Radiant LAK-205 Coil / Ribbon Mid-Size Heater
The caution light comes on; on my lakewood LAK-205? Can i still use it or just throw it away?
    Problem Solver:
  • 14 Answers
Lakewood has filed for Chapter 7 liquidation. There isnt any parts, service or manuals available from thier website.
Posted on Feb 22, 2010
  • 34 Answers
Visit this page for service center information as well as parts:
http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
Can i get just the motor?
Here is customer service for Lakewood
https://secure.jardenstore.com/ContactUs.aspx
Sometimes a replacement motor is more expensive than a whole new fan. I know, it seems a shame to throw out a whole fan because a motor is more expensive.
Feb 05, 2011 | Lakewood HV 18-c Floor / Box Fan
I wanted to clean inside the heater and I happened to disconnect two wires and now that I connected them back to where I thought they belong it makes a short is there a way to see a diagram of the wiring...
I am not sure but if the wires comes from the resistors try to see how they were banded before. You cannot make a short. you will see exactly what you did when you'll power it up.
Jan 29, 2011 | Lakewood Economy Radiant LAK-205 Coil /...
HAVE SOME RUST ON AN OIL FILLED RADIATOR HEATER. WHAT CAN I SEAL A LEAK WITH?
they are supposed to be welded so i wouldn't recomend patching with anything else and you would need more oil if it s been leaking throw away and buy new, it would probably be cheaper!
Nov 29, 2010 | Lakewood Oil-Filled Electric Radiator...
I have a Lakewood Model 750 Strip Heater and the caution light is lit. How do I get the unit working again.
chances are the thermostat has been damaged due to excessive heat or corrosion has accumulated on the connections coming from the temperature dial. it is possible to bypass this component but not advisable, if you choose to do so, please monitor the heater at all times and be sure to unplug it while not in use. replacement parts are still available.
do not attempt to service the heater while it is plugged in to an electrical outlet.
Nov 05, 2010 | Lakewood 750 Oil Filled Baseboard Heater
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
Help! Dog Bit Through Electrical cord on Lakewood 2727. How to replace cord???
another option for you would be to use crimp on terminal connectors(**** connectors) you may purchase these from most hardware stores. Even using these I would still tape around the outside to ensure a good insulating surface.
Apr 28, 2008 | Lakewood 2727 Heater
Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Jan 07, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood Economy Radiant LAK-205 Coil / Ribbon Mid-Size Heater Logo
726 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
